Current Build:
- CPU: Ryzen 5600X
- GPU: Nvidia 3080
- Motherboard: MSI Tomahawk X570s
- RAM: DDR4 32GB 3600MHz
- PSU: Corsair RM750x
Goal:
- Run Linux as the host and a Windows VM for gaming with near-bare-metal performance.
- Host should handle video playback in 1440p/4k while the VM runs games at 1440/4k.
Issue:
- Unable to fit a second GPU without choking the 3080.
Plan:
- Considering upgrading to a Ryzen 9 9950X3D (for it’s onboard graphics and passing the dGPU to the VM and using LookingGlass to use the VM), but unsure if it’s overkill.
Questions:
- Is a 9950X3D a good choice for my use case? Is it overkill? (running host GUI on CPU is probably not ideal so I thought getting something more powerful would help so more of it can be dedicated to the VM)
- How should I split CPU resources between the host and VM for optimal performance? Would I be able to pass the 3d cache to the VM?
- Is an X870 motherboard overkill for my needs? I have 4 storage drives and want the headroom for potential future upgrades, including a second GPU or a 50 series card. These boards seem to be one of the few that have enough lanes to do onboard graphics for 2 monitors at 1440/4k
Any advice/thoughts is greatly appreciated ![]()
