VFIO 2023 / Radeon 7000 Edition [WIP]
sounds more like a timing issue, try “invtsc” and set “migratable=no”
@wendell Not sure how confident you should be proclaiming the 7000 series good for VFIO. I have an issue where it works with flat titles fine, but for VR…
files catbox moe dd6dub.mp4
I have vfio bound to the card at boot, and haven’t done anything different then you would for a nvidia card than manually passing the bios rom and the rebar stuff. This used to work at some point on the 6 series kernels, but now even on 6.1 Its just doesn’t work anymore. Any ideas? My whole pc goes down. All I can tell from having dmesg -w in another terminal is that it’s some sort of page fault in vfio.
EDIT: I have resource0 set to 32GB and resource2 set to 2MB as I read from posts by Aiber that that was the correct way to get rebar working. When I get more time I’ll try what I just saw here about some weird relationship between the sizes now?
I have both settings, except “migratable=off” instead of “no”
well I don’t play PUBG and don’t test everything in detail, the QEMU ChangeLog says “no”
KVM
  • New “invtsc” (Invariant TSC) CPU feature. When enabled, this will block migration and savevm, so it is not enabled by default on any CPU model. To enable invtsc, the migratable=no flag (supported only by -cpu host, by now) is required. So, invtsc is available only if using: -cpu host,migratable=no,+invtsc.
He’s playing PUBG and doesn’t seem to have a problem, but things may have changed
When I try to safe it:
Error changing VM configuration: XML error: Invalid value for attribute 'migratable' in element 'cpu': 'no'.
Yes, that seems to have been changed again
https://listman.redhat.com/archives/libvir-list/2020-July/msg00181.html
Anyway my thought was, if you can start PUBG, then the ANTI-Cheat component doesn’t seem to complain about your configuration at first, that you then get kicked out of the game after plying for a while could be a timing problem
It doesn’t happen though, when I change two settings as described above, without changing timings.
ZFS broken in this kernel ?
modprobe: FATAL: Module zfs not found in directory /lib/modules/6.4.3-060403-generic
Can somebody tell me how to get back to 6.2, tried with mainline but after restart I’m still on 6.4 :frowning:
I just ran my setup again recently but with rebar set to 8GB and 8MB and got new logs. Same exact thing occurs. Does anyone else even do VR in VFIO on a 7900xtx? No idea how this used to work.
dmesg, domain xml, and libvirt logs: dpaste com AELLYGS7J
This exact same setup works with a RTX 3090 with no changes.
Oh i so look forward to this, Maybe i can get some answers as to my CPU pinning and process isolation does not work for me, performance dies HARD when i isolate my VM to one CCD on either my 3900x or 7950x. dose not matter what CCD I choose.
But it works well enough for what i use it for. Just trying to make it easier to do a windows install with no monitor or dummy plug placed into the GPU. MDT+PSD is getting me really close to that 2nd goal
I’ve spent the whole day testing REBAR, I’ll keep my hands off it for now, hardly any performance gains for a lot of trouble.
The AMD driver doesn’t recognize it, but GPU-Z says it’s running.
I usually don’t have any driver issues, but the VM with REBAR config now has driver timeouts all the time.
While I’m on the subject of the driver, the current AMD driver is unusable without an internet connection, they’re crazy at AMD, how can’t you test something like that?
I had to open a list with 20 IP-A so that the driver interface responds to inputs.
Edit: wrong track, driver timeouts were caused by Futuremark-Systeminfo
no :), but one of your main concerns are latency.
Have you tested this yet?
virt-xml win11 --edit --confirm --qemu-commandline="--overcommit cpu-pm=on"
FWIW, SteamVR works for me in the VM (see this post for the details on my VFIO setup). I use the Valve Index with the USB cable connected to a passed-through USB controller.
RIP
soft reset issue with AMD RX 7900 XT (1st party) after one restart of the VM:
# virsh start win10
error: Failed to start domain 'win10'
error: internal error: Unknown PCI header type '127' for device '0000:0d:00.0'
virsh dumpxml win10
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>win10</name>
  <uuid>a1b2e3e0-1749-437c-8aa3-8114bc1b23bc</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <vcpu placement='static'>4</vcpu>
  <os>
    <type arch='x86_64' machine='pc-q35-8.0'>hvm</type>
    <loader readonly='yes' secure='yes' type='pflash'>/usr/share/edk2-ovmf/x64/OVMF_CODE.secboot.fd</loader>
    <nvram template='/usr/share/edk2-ovmf/x64/OVMF_VARS.fd'>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
    <boot dev='hd'/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <vendor_id state='on' value='other'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <smm state='on'/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='on'/>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
    <timer name='hypervclock' present='yes'/>
    <timer name='tsc' present='yes' mode='native'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type='file' device='disk'>
      <driver name='qemu' type='qcow2'/>
      <source file='/DataRecover/Backup/Image/win10ltsc.qcow2'/>
      <target dev='sda' bus='sata'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <disk type='file' device='cdrom'>
      <driver name='qemu' type='raw'/>
      <target dev='sdb' bus='sata'/>
      <readonly/>
      <address type='drive' controller='0' bus='0' target='0' unit='1'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0x15'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0x16'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0x17'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x7'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0x18'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='10' model='pcie-root-port'>
      <target chassis='10' port='0x19'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
    </controller>
    <controller type='pci' index='11' model='pcie-root-port'>
      <target chassis='11' port='0x1a'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
    </controller>
    <controller type='pci' index='12' model='pcie-root-port'>
      <target chassis='12' port='0x1b'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x3'/>
    </controller>
    <controller type='pci' index='13' model='pcie-root-port'>
      <target chassis='13' port='0x1c'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x4'/>
    </controller>
    <controller type='pci' index='14' model='pcie-root-port'>
      <target chassis='14' port='0x1d'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x5'/>
    </controller>
    <controller type='sata' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:93:cb:3d'/>
      <source bridge='br0'/>
      <model type='virtio'/>
      <link state='down'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
      <target type='isa-serial' port='0'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
      <target type='serial' port='0'/>
    </console>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <tpm model='tpm-crb'>
      <backend type='emulator' version='2.0'/>
    </tpm>
    <audio id='1' type='none'/>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <source>
        <address domain='0x0000' bus='0x0d' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0d' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0d' slot='0x00' function='0x2'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0d' slot='0x00' function='0x3'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
    </hostdev>
    <watchdog model='itco' action='reset'/>
    <memballoon model='none'/>
    <shmem name='looking-glass'>
      <model type='ivshmem-plain'/>
      <size unit='M'>256</size>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/>
    </shmem>
  </devices>
  <qemu:override>
    <qemu:device alias='ua-stupid'>
      <qemu:frontend>
        <qemu:property name='x-vga' type='bool' value='true'/>
      </qemu:frontend>
    </qemu:device>
  </qemu:override>
</domain>
lspci -vvvs 0d:00.0
0d:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX] (rev cc) (prog-if 00 [VGA controller])
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 1002
        !!! Unknown header type 7f
        Interrupt: pin ? routed to IRQ 25
        IOMMU group: 30
        Region 0: Memory at d0000000 (64-bit, prefetchable) [size=256M]
        Region 2: Memory at e0000000 (64-bit, prefetchable) [size=2M]
        Region 4: I/O ports at f000 [size=256]
        Region 5: Memory at fbb00000 (32-bit, non-prefetchable) [size=1M]
        Expansion ROM at fbc00000 [disabled] [size=128K]
        Kernel driver in use: vfio-pci
        Kernel modules: amdgpu
what motherboard? can you also setup your vm with an external bios file instead of the one built into the card?
Still using the Gigabyte X570 Aorus Master.
IOMMU groups are fine
$  bash -c 'shopt -s nullglob; for g in /sys/kernel/iommu_groups/*; do echo "IOMMU Group ${g##*/}:"; for d in $g/devices/*; do echo -e "\t$(lspci -nns ${d##*/})"; done; done'
IOMMU Group 0:
        00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 1:
        00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 10:
        00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 11:
        00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 12:
        00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 13:
        00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
        00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 14:
        00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0 [1022:1440]
        00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1 [1022:1441]
        00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2 [1022:1442]
        00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3 [1022:1443]
        00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4 [1022:1444]
        00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5 [1022:1445]
        00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6 [1022:1446]
        00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7 [1022:1447]
IOMMU Group 15:
        01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO [144d:a80a]
IOMMU Group 16:
        02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream [1022:57ad]
IOMMU Group 17:
        03:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a3]
IOMMU Group 18:
        03:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a3]
IOMMU Group 19:
        03:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a3]
IOMMU Group 2:
        00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 20:
        03:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a3]
IOMMU Group 21:
        03:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a4]
        08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
        08:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
        08:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 22:
        03:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a4]
        09:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 23:
        03:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge [1022:57a4]
        0a:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 24:
        04:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961/SM963 [144d:a804]
IOMMU Group 25:
        05:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
IOMMU Group 26:
        06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 27:
        07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 01)
IOMMU Group 28:
        0b:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch [1002:1478] (rev 10)
IOMMU Group 29:
        0c:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch [1002:1479] (rev 10)
IOMMU Group 3:
        00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 30:
        0d:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX] [1002:744c] (rev cc)
IOMMU Group 31:
        0d:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 HDMI/DP Audio [1002:ab30]
IOMMU Group 32:
        0d:00.2 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 USB [1002:7446]
IOMMU Group 33:
        0d:00.3 Serial bus controller [0c80]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:7444]
IOMMU Group 34:
        0e:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1)
        0e:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
IOMMU Group 35:
        0f:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 36:
        10:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 37:
        10:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
IOMMU Group 38:
        10:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 4:
        00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 5:
        00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 6:
        00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 7:
        00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8:
        00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 9:
        00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
Using a dumped vBIOS now and report back when it happens again. Haven’t played around too much with that card yet due to other unrelated hardware issues (broken AIO + PCH fan).
is a MSI TRX40 Pro Wifi Mobo capable of doing VFIO? i found a full build with a 3960X within my greater area for $1650. im thinking of grabbing it for parts for a VFIO capable build.
In terms of IOMMU groups it’s great, every device is in their own IOMMU group.
But I wouldn’t recommend anyone with high fps(like 120+) gaming in mind to buy a Threadripper platform, CPU bottleneck is quite sever.
I can’t do that at my age anymore. The closest I’ve ever gotten is 100 stable on shipment in MW22.
