Hi everyone.
Is VDI for Gaming possible on local network?
If so, is PCoIP a good solution or only KVM over IP can provide low/zero latency?
I would say it is possible on a local network, though in most situations people would recommend having a server that can handle GPU pass through (via a VM). Though you may want to clarify what exactly you are trying to achieve via VDI?
I have no idea wtf PCoIP is but from what I can find it is some custom marketed KVM product… for better support I would lean towards KVM as it just works…
