@QEMM, that's what the site espouses in great detail; using web searches to find exactly what you're looking for, through a structured before, during and after of considered searching.
Although I didn't/haven't learned all it can teach, the base ethos is learning to define what you want to find and teaching the tools to reach that defined state you're looking for. I've always felt that this was a valuable resource for myself and I thought I'd share its wisdom with the Forum :-)
A quote from the Warning Page http://searchlores.co/warning.html:
The correct 'use' of this site will give you remarkable power. After some study (a couple of months, usually... YMMV) you'll be able to find anything on the web.
Any image, any film, any software, any music, any solution, any book. Anything that has been produced by humans on our planet, in any language, provided it can be digitized, duh...
A good seeker can be a quite dangerous beast, though. Those that do learn how to search, which is what this site is intended to teach, will be able to find on the web -if needs be- ANY KNOWLEDGE, and thus -also- zillions of possible exploits. Innocent ones, milder ones, and quite nasty ones as well.
You will learn here how to search, you will have to decide yourself what to search. This site offers raw, free knowledge. As always, sheer power can be used for 'evil' deeds and/or for 'good' deeds (let's leave aside, for now, the rather complex question of what would be 'evil' and what would be 'good' nowadays, just use your own parameters).
Spring in, if you dare! Again, you have been warned: at first you'll only fathom the existence of the abyss, only later you'll understand its real depth and width.
[Edited in after 1st save]
I agree others may try and enforce their view of what's true or not; I personally don't use Facebook and Google, on the other hand is almost the de-facto Search and I do use that... But I don't take what it brings up as the definitive answer, on many of the searches I make that have a greater complexity to them.
What I hoped by posting this, is to introduce a source that's helped me be a better web searcher, far better than the more casual user and hopefully share some knowledge to help others find what they seek, whether that's a better recipe or a better source of information.
