Using RK3588 to pass a ZFS vDEV as an NVMe Drive to host
What
My idea is to have a set of drives in my desktop connected to an RK3588 running ZFS and presenting the vDEV as an NVMe drive to the host PC.
Why
-I don’t what to run ZFS on my host OS for simplicity.
-Modern Motherboards have stuff all SATA ports.
-Most Motherboards have a slow Ethernet port.
-Because a red bearded Viking from TekSyndicate said its the best!!
How
software
the RK3588 running Debian based distro with ZFS installed will switch some of the PCIe Gen3 lanes into endpoint mode and pass the ZFS vDEV to the NVMe endpoint
hardware
make an M.2 card that
  • splits the first two of the lanes to a connector (you suggestions would be help full) and that would go the a PCIe or M.2 slot on the host.
  • sends the other two lanes to a an M.2 slot and put one of those cheep AMS1166 adapters in it.
why M.2?
M.2 card could be used with most RK3588 boards, and seemed the cheapest way forward. I was starting to KiCAD a PCB for an RK1 SODIMM module :zany_face:
Story
This idea has been rattling around in my head for a wile now, i think it started with ‘why doesn’t someone put ZFS on the raid controller’ and seeing someone doing endpoint stuff with an RK3399.
well recently I’ve noticed people starting to use AI to help them with there projects, and i started asking google about arm chips that have endpoint mode and lots of PCIe lanes with no luck. But I knew about the RK3588 endpoint mode from researching diffent projects, and started asking the AI about building this. the Atom P5000 was also mentioned, but got caned because there was no cheep way of getting one. I’ve also just discovered the CIX P1 from the radxa Orion O6, but i think that is still a bit to new to play with.
Then Wendel (he reminds me of that Viking) put out a video about Devembor and some people being a little to keen and knot knowing anuff to ask the right questions, so as someone who has been lurking here for years I’m asking for help.
Hey, did you get anywhere on this DAS-inside the computer project?
Over the years, there has been several “computer running on a PCIe socket” ideas, but they were mostly for KVM/ baseboard management systems
I’ve not noticed them to offload storage, but it is an interesting idea, to fabri-cobble a jerry rigged raid card.
GPU’s basically have processors and ram and such, and (at least one) AMD card even had storage.
But presumably firmware locked down, and the card would not be modifiable for hardware hacking, as well as being over powered for the task!
