I'm trying to access a dynamic disk using ldmtool from this guide: https://wiki.archlinux.org/index.php/Dynamic_Disks
It detects the partitions:
ldm> scan /dev/sdc
"f1b87e11-d16f-11e4-b62a-bc5ff4abc56e"
ldm> show diskgroup f1b87e11-d16f-11e4-b62a-bc5ff4abc56e
"name" : "WIN-JLETFH6M5QG-Dg0",
"guid" : "f1b87e11-d16f-11e4-b62a-bc5ff4abc56e",
"volumes" : [
"Volume2",
"Volume1",
"Volume3"
"disks" : [
"Disk1"
ldm> show volume f1b87e11-d16f-11e4-b62a-bc5ff4abc56e Volume1
"name" : "Volume1",
"type" : "spanned",
"size" : 335544320,
"chunk-size" : 0,
"hint" : "D:",
"partitions" : [
"Disk1-01",
"Disk1-04"
ldm> show volume f1b87e11-d16f-11e4-b62a-bc5ff4abc56e Volume2
"name" : "Volume2",
"type" : "spanned",
"size" : 1830838272,
"chunk-size" : 0,
"hint" : "E:",
"partitions" : [
"Disk1-02",
"Disk1-05"
ldm> show volume f1b87e11-d16f-11e4-b62a-bc5ff4abc56e Volume3
"name" : "Volume3",
"type" : "simple",
"size" : 1740636412,
"chunk-size" : 0,
"hint" : "G:",
"partitions" : [
"Disk1-03"
but when I try to map them:
ldm> create all
Unable to create volume Volume2 in disk group f1b87e11-d16f-11e4-b62a-bc5ff4abc56e: ldm_vol_WIN-JLETFH6M5QG-Dg0_Volume2: Stacking NODE_DEL [verify_udev]
Unable to create volume Volume1 in disk group f1b87e11-d16f-11e4-b62a-bc5ff4abc56e: ldm_vol_WIN-JLETFH6M5QG-Dg0_Volume1: Stacking NODE_DEL [verify_udev]
Unable to create volume Volume3 in disk group f1b87e11-d16f-11e4-b62a-bc5ff4abc56e: ldm_vol_WIN-JLETFH6M5QG-Dg0_Volume3: Stacking NODE_DEL [verify_udev]
Any help? I eventually want to mount one or two of them at startup from the fstab file but first I need to access them.
