Any good resource suggestions on setting up a reverse proxy in a VPS with a public IP address to allow my homelab internet connection?
I have currently some services I would like to access through the internet, preferably using a VPS as as a reverse proxy to my home network. My home network is behind Carrier grade nat, so I cannot really use my home connection directly.
Any good suggestions or providers? Or guides? Or something you want to contribute?
Can you believe it, apparently Tailscale also has a feature to do what you want as well. Forward traffic from the internet into your tailnet. Tailscale Funnel · Tailscale Docs
Just ensure anything you expose is configured securely.
Just checked that the funnel works only on the local machine that the service runs on, which is a VM for me. Probably doable, but I am thinking about the long term viability of the solution.
