Used Xeons after x99/broadwell/LGA2011
When people talk about used xeons for PC/HomeLab almost all of the time they are talking about Xeons up to broadwell in x99/2011-v3, but intel has been constantly releasing “new” Xeons, why are people not picking them up used,
example try to find a x299 the options are limited
I am building (another) 2nd gen scalable for the house.
LGA3647 MoBo’s are anything but cheap as they still make CPU’s for the socket.
Performance per watt is higher than the consumer counterparts when you pick the correct skus.
But everyone is after chart topping performance instead of balance.
Xeon 2nd gen scalable are more efficient than EPYC… until Genoa.
Genoa and later, it’s a no brainer but that’s a build that’s 3-6x the price.
Mostly because broadwell-e (x99/2011-v3) was the last time when you could put a Xeon in a consumer motherboard and it worked.
i would assume Chinese motherboard manufacturers would have “hacked in” support by this point like they have for others (like lga 1151)
“hacking it in” comes with drawbacks, including missing IME, power profiles, etc. Besides I’m assuming post 1151 there are more incompabilities than just IME lock.
