? use Optane as cache/scrach disks pop os build
can i use an if so how a
Intel Optane P1600X 118 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
vi a
Sabrent NVMe M.2 SSD to PCIe X16/X8/X4 Card with Aluminum Heat Sink (EC-PCIE)
on my pop os build
Gigabyte B550M DS3H Micro ATX AM4 Motherboard
and set the drive and adapter in the 2nd pci x16 port an config as a cache/scrach will that work an if so how do i set that up ?
The same way linux swap works on any block device.
Format a swap partition, mount as swap, and enable swapon.
thanks for that , do you think the optane will perform better then a p31 nvme or equal to it
I would think so, going off what I can find in google, and the general sameness of all TLC NAND under heavy nonlinear workloads. Could be as much as 2~3x faster in swappiness.
thanks for that insight
