Should I use 4 X 4G or 2 X 8G on my mother board. Should I fill all 4 slots or just use 2? Does either way have any benefits? I will not be upgrading to 32G.
GA-990FXA-UD3
FX8350
GA-990FXA-UD3
FX8350
2 slots is generally more reliable from my experience, but I'm also pretty sure it's more expensive, so it doesn't make a huge difference.
Using just two modules is supposed to be better for overclocking too, so if you're trying to get the most out of your cpu, then it's usually better to only populate two slots. Although, it probably won't make a huge difference, if any.
i believe most manufacturers recommend 2x...gb over 4x...gb.
and i think that if you use a 32bit os it sometimes won't recognize or use the extra 2 slots. (but don't quote me on that)
I am going to install Windows 7 64 bit.
edit: I installed 8.1 64 bit.
I think I will go with 2 X 8, less parts to go wrong. Thanks
