Can you recommend a USB 3 hub for your “1.4 Display Port KVM Switch - Dual Monitor - Two Computer KVM”? I need at least two more USB 3 ports than my unit has (my DAC, mic, and webcam do not work on the USB 2 ports).
Thanks!
Thanks!
probably a powered anker brand hub? Some other users here use the kvm with a hub and may be able to chime in
