1.4 Display Port KVM Switch - Dual Monitor - Two Computer
5-gigabit
Problem:
I’m trying to use a USB-C (computer) to displayport (monitor) cable. The cable works when going directly to the monitor, but with the KVM in the middle there is no signal. Are there compatibility issues when using this configuration?
That’s correct. I got some other cables to try and same result. A couple of times I did get a video signal to come through but it was not stable and locked my machine up.
The repeater seems to have done the trick. I installed it on the DP out from the KVM and everything has been stable. Apparently the USB-C signal wasn’t as strong as a straight displayport one.
