USB-C KVM Switch v3 - No DP signal
Hi,
I’m having issues with my new USB‑C KVM and confirmed that the DisplayPort path is not functioning. USB peripherals work, but no DP signal is ever passed through the KVM. Below is everything I’ve tested.
Hardware involved:
  • Dell Precision 7680 (USB‑C with DP‑Alt‑Mode)
  • Surface Laptop Studio 2 (USB‑C with DP 1.4 Alt‑Mode)
  • Dell S3422DW monitor (3440×1440, DP 1.2)
  • USB-C KVM Switch v3 (USB-C KVM Switch v3 (with USB Power Delivery / 135watts) — Level1Techs Store)
  • VESA‑certified USB‑C and DisplayPort cables
    • Anker USB C to USB C Cable, Type-C 6ft (ASIN = B088NRLMPV)
    • IVANKY 8K DisplayPort Cable 1.4, VESA Certified DP Cable 6.6ft (ASIN = B07VVJZJ2P)
What works (direct connection):
  • Both laptops → USB‑C → DP adapter → DP cable → Dell S3422DW work immediately.
  • This confirms the laptops, DP cable, monitor, and DP‑Alt‑Mode are all functioning.
What fails (through the KVM):
  • Laptop → USB‑C → KVM → DP cable → Dell S3422DW always shows:
    “No DP signal from this device.”
  • No flicker, no link training, no EDID handshake — the monitor never detects a DP source.
  • USB keyboard/mouse through the KVM work normally.
Troubleshooting performed:
  1. Full power‑cycle of the KVM:
  • Unplugged all host cables, DP cable, peripherals, and power for 30+ seconds.
  • Reconnected only power, one USB‑C host, and DP out → monitor.
  • Same “No DP signal from this device” message.
  1. Tested both USB‑C host ports on the KVM.
  2. Tested with multiple known‑good, VESA‑certified USB‑C cables.
  3. Verified monitor DP input, DP cable, and both laptops by bypassing the KVM (all work).
  4. Tried minimal configuration with only power + one host + DP out.
  5. Tried USB-C Bandwidth Allocation in both 2-Lane and 4-Land.
Conclusion:
The KVM is not outputting any DisplayPort signal on either host port. USB works, but the DP subsystem (DP OUT port or internal DP mux) appears to be non‑functional.
Please advise.
Thank you.
Just to follow up here I believe we sorted you out via email and it shooould be a cable issue.
