Bit of a noob question but I can’t find an answer here or elsewhere:
Are there devices other than storage drives that I’d need the 10gbps usbc option for? Any advantages that I might be missing if I picked the 5gbps?
Let’s start here, what do you need the cable for?
usb-c can support faster charging too generally (but only with support of source + cable + device)
If you aren’t using large removable storage then then it probably isn’t necessary. I would just say that if you plan on keeping the KVM for several years then I’d just spend the extra $90 and not worry about it.
Yeah, that’s what I’m thinking at this point. Thanks
