USB Audio: Phone to Car
Hello, All!
I have been struggling with the USB audio issue for years as an Android user and I was resigned to my fate until today when a friend and myself took a road trip together. I asked him to DJ, since I was the driver, and something incredible happened! His iPhone was connected to my car (2013 Ford C-Max) via Lightning to USB-a cable and it just worked! He was streaming over Spotify and it even had album art, no less! Needless to say, I was flabbergasted as I’ve had the car for years and have had a Google Pixel 5a and now a brand new Pixel 8a and I’ve never experienced that level of seamless integration before.
Is Android 15 capable of something like this (meaning I’m an idiot and didn’t see the option) or did Google break something that Apple hadn’t? I’ve spent hours googling with no clear answer why his phone works, but mine doesn’t. My only current solution as a Tidal Music subscriber is to purchase an external DAC like the AudioQuest Dragonfly to output an analog 24/192k stream over a 3.5mm to RCA adapter … until my friend plugged his phone in and it just worked.
Have any of you dealt with this … irritating issue and had positive results?
**Edit: I wanted to clarify that the car does try to index all media files and can play MP3s from my phone, but there’s no way to put audio out through the USB. Basically, there’s no way to control it from the phone and it obviously doesn’t see any streaming files like from Tidal.
I have a 2011 honda accord and a samsung galaxy s20 fe 5g phone running android 13. Now the car’s infotainment system is dumb as in am / fm / cd / aux in dumb. The next trim package up has the gps and sirius / xm upgrades.
Anyway I’ve got mu phone connected to a usb dongle that splits out from a usb type c to a type c for power and a female 3.5mm headphone jack. I just have a usb tpe c cable plugged into the dongle and a male to male 3.5 mm stereo headphone cable plugged into the other side of the dongle and have the car’s radio set to aux and all of my music plays thru the cars speaker with no issues. All the music is controlled thru the phone so no indexing or media images transferred to the car.
I will have to at some point figure out how it will work with a modern infotainment system.
Have you looked at what version of android auto is installed on the phone and is it updated? Also I do not know if the apps on the car are updateable and if so how they are done.
Just my thoughts!
Did Ford support the most popular phones and say fuck everything else?
I think I’m going to have to use something like what you’ve got @thetazman. My car’s infotainment system doesn’t actually have Android Auto, but it does have the SiriusXM feature and I have to say…sounds like a tin can. The receiver must be an early model with low bandwidth or something. Hopefully when I upgrade vehicles to a new model EV, it will have a better infotainment system; perhaps an ID4? :star_struck:
I sincerely think so! It’s proudly badged as Sync by Microsoft and it the single worst infotainment system I have encountered. It’s unstable and constantly undergoing “maintenance”; I think it’s just nearing failure. Bluetooth is…don’t even get me started. I was totally surprised his iPhone just worked so seamlessly.
I would just use bluetooth. The usability outweighs the sound quality.
For my use case blue tooth is not an option due to the age of the car.
I do use bluetooth on occasion, but it’s locked to the SBC codec and sometimes unstable. It will work until I get the Dragonfly DAC. It’s always funny when packets are lost and voices on audiobooks speed up and slow down randomly. Perhaps if it were a newer transceiver with LDAC or aptX HD it would be more secure, reliable, and preserve some fidelity.
Would a Bluetooth adapter be an option for your car? Something like the Kinivo BTC450?
This is what I have for my use case:
Until I replace the car I’m just plugging into the aux port of the car’s head unit and being ghetto af for the time being.
bruh
Why the push for blue tooth when aux works?
Push? I replied to it not being an option.
I personally prefer aux due to using Tidal HiFi 24/192khz, but Bluetooth is convenient for some; most people listen to music that is somehow lossy compressed already.
Does the audio quality suit you? What format do you usually use to play music?
Sorry!! My bad!
Only option I have at this time!
I think by push, tazman merely meant to suggest.
Also why use wireless tech? You dont have to emit beacons around while you drive with wired Aux/3.5mm
Just having a phone does that anyway
Fair enough but at least your reduce beacon pings.
I have my wifi and bluetooth mostly off and i automatically set the wifi to turn off once it disconnects after a short amount of time. Bluetooth is mostly off and i only use them sparingly.
While you may not want to go this route, I have been using a charger/bluetooth receiver that broadcasts a very short range FM signal. You just need to set it up to use a “vacant” spot on the FM scale so that stations in your area don’t interfere. Since it just uses FM, it should work for any vehicle with a working radio. This is the one I am using: https://www.amazon.com/dp/B07F2RTN5Z?ref=ppx_yo2ov_dt_b_fed_asin_title
I don’t stream music, so have been using the Musicolet (android) app to play music and old time radio shows when I take longer trips.
The AudioQuest Dragonfly Colbalt should be here in a day or so! I can once again begin listening to Tidal and Idagio streams in high fidelity; it’s been too long. As a Lyft Driver I pay very close attention to my playlists and audio quality and it’s been pretty poor since the phone upgrade with no 3.5mm jack.
I have a friend that has a super old beater van and he uses this and it’s surprisingly reliable.
