I have the same enclosure and it works on 20Gb on Linux. I’m using the port on my Asus proart x670e. The front port on my case also works, but it is a bit unreliable (possibly due to the cable of the case). The rear port is flawless.
lsusb -v:
Bus 004 Device 002: ID 174c:2362 ASMedia Technology Inc. ASM236X series
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.20
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x174c ASMedia Technology Inc.
idProduct 0x2362 ASM236X series
bcdDevice 1.00
iManufacturer 2 Asmedia
iProduct 3 ASM236X series
iSerial 1 0000000000C0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0079
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 15
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 4
bInterfaceProtocol 98
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
MaxStreams 32
Data-in pipe (0x03)
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
MaxStreams 32
Data-out pipe (0x04)
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
MaxStreams 32
Status pipe (0x02)
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
Command pipe (0x01)
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x002a
bNumDeviceCaps 3
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x0000f41e
BESL Link Power Management (LPM) Supported
BESL value 1024 us
Deep BESL value 61440 us
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
SuperSpeedPlus USB Device Capability:
bLength 20
bDescriptorType 16
bDevCapabilityType 10
bmAttributes 0x00000001
Sublink Speed Attribute count 2
Sublink Speed ID count 1
wFunctionalitySupport 0x1100
Min functional Speed Attribute ID: 0
Min functional RX lanes: 1
Min functional TX lanes: 1
bmSublinkSpeedAttr[0] 0x000a4030
Speed Attribute ID: 0 10Gb/s Symmetric RX SuperSpeedPlus
bmSublinkSpeedAttr[1] 0x000a40b0
Speed Attribute ID: 0 10Gb/s Symmetric TX SuperSpeedPlus
Device Status: 0x0001
Self Powered
lsusb -t
❯ lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 006: Dev 002, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 006: Dev 002, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 006: Dev 002, If 2, Class=Wireless, Driver=[none], 480M
|__ Port 007: Dev 003, If 0, Class=Vendor Specific Class, Driver=[none], 12M
|__ Port 007: Dev 003, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 008: Dev 004, If 0, Class=Human Interface Device, Driver=[none], 480M
|__ Port 008: Dev 004, If 1, Class=Billboard, Driver=[none], 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/5p, 20000M/x2
|__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=uas, 20000M/x2
/: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/12p, 480M
/: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/5p, 20000M/x2
/: Bus 007.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 008.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 009.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 002: Dev 017, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 003: Dev 018, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 018, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 018, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 019, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 019, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 010.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
|__ Port 002: Dev 008, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 011.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 012.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/0p, 5000M
