EDIT: What’s left has been brought to e-waste. Thanks for helping me offload this!
Everything is free because everything must go - anything that doesn’t get taken will go straight to e-waste in March.
I’ve been cleaning out some old junk in preparation for a move and don’t feel like trying to sell this stuff or haul it around any longer, so I’m giving it away instead. I might add more stuff in the coming days (I’ll bump the thread if I do), but for now, this is what I’m starting with.
You pay shipping + PayPal fees (and if outside the US, you are responsible for any import fees/VAT). I’ll ship anywhere USPS and UPS go. If you’re willing to drive to Catawba County, NC, pick-up is free.
All the warranties are long expired, no significant testing (memtest, prime95, etc.) has been done, and everything is as-is.
Without further ado, here are all the items on offer:
Product | Details | Photos | Still Available? |
CPU - AMD Ryzen 5 2400 G | Purchased for a project that ended up not happening; never tested it myself but it should work | https://i.imgur.com/HOoN1HB.jpeg | Yes |
RAM - Team Group TLRED38G1600HC9BK (2x8 GB DDR3-1600, CL 9-9-9-24, 1.5V) | Purchased for a project that ended up not happening; never tested it myself but it should work | https://i.imgur.com/PqUXIxV.jpeg | Yes |
GPU - EVGA GTX 280 | I have no convenient way to test this, but it worked the last time I used it (5+ years ago). It’s been sitting in an anti-static bag ever since. | https://i.imgur.com/G3MMgmW.jpeg Imgur: The magic of the Internet https://i.imgur.com/nO2ig6k.jpeg | Yes |
Monitor - ASUS VS229H-P (1080p 60 Hz, 21.5", IPS, w/stand + power cord) | No defects; just minor wear and tear. Was VESA mounted for 8 years before being shoved into a closet. Picture of the monitors turned on was pre-shoving into closet. | https://i.imgur.com/FSkQ4Im.jpeg https://i.imgur.com/sYityqS.jpeg | Yes |
Monitor - ASUS VS229H-P (1080p 60 Hz, 21.5", IPS, w/stand + power cord) | Around 25% of the time, immediately after startup, it’ll glitch, reboot, and then work like normal. It has never rebooted unexpectedly after startup, only during. Minor wear and tear. Also VESA mounted for 8 years. Picture of the monitors turned on was pre-shoving into closet. | https://i.imgur.com/FSkQ4Im.jpeg https://i.imgur.com/sYityqS.jpeg | Yes |
Monitor Mount - EasyMountLCD 002-0020 (free-standing 75x75/100x100mm triple monitor mount; supports up to 27" monitors, unknown weight limit) | I included two photos of the monitor stand in use as I never took a picture after removing the monitors but before I disassembled it. I think it has all accessories except the cable management clips (which broke off years ago). It was used for close to a decade before being replaced. Minor wear and tear. | Imgur: The magic of the Internet https://i.imgur.com/psG0cnj.jpeg https://i.imgur.com/cKssk5N.jpeg https://i.imgur.com/sYityqS.jpeg | Yes |
Keyboard - Adesso MKB-135B full-size w/Cherry MX Blues (PS/2 KB w/passive USB adapter, USB hub, and audio passthrough) | Tested just now; works fine. Plugged a USB drve into both USB ports, they work fine. | https://i.imgur.com/VEhyaLI.jpeg https://i.imgur.com/oMjWWK0.jpeg | No |
Keyboard - CM Storm Quick Fire Rapid TKL w/Cherry MX Browns (USB KB w/cable) | Tested just now; works fine. | https://i.imgur.com/Y9EzB8w.jpg https://i.imgur.com/JEQEx6S.jpg | No |
Keyboard - CM Masterkeys S TKL w/Cherry MX Browns (USB KB w/cable, extra WASD-cluster red keys) | Tested just now; works fine. | https://i.imgur.com/ZgDqd2k.jpeg Imgur: The magic of the Internet Imgur: The magic of the Internet https://i.imgur.com/9nAceiN.jpeg | No |
Mouse - Logitech G660 MMO RGB USB mouse | All buttons work (right-most = CTRL, left buttons are 1234567890-+), scroll wheel works, mode switcher works, DPI adjust works. Did not test with Logitech software because I do not have Windows installed. | https://i.imgur.com/97iIq2o.jpeg https://i.imgur.com/Vh3ZUfl.jpeg | No |
Mouse - ZOWIE USB mouse, unknown model | Tested just now; works fine. | https://i.imgur.com/lYDivUW.jpeg https://i.imgur.com/YO74RvK.jpeg | No |
KVM - Tripp-Lite B006-VU4-R with cables for 4 PCs + power brick + manual | VGA + USB KB/M KVM. Used this back in 2020 then shoved it into storage; worked just fine the last time it was powered on. | Imgur: The magic of the Internet https://i.imgur.com/iBVJJd8.jpeg https://i.imgur.com/ENQJ7j4.jpeg | Yes |
Laptop - Dell Inspiron 1520 (Unknown CPU, 3 GB RAM, no HDD, no power brick) | Not sure if it boots since I do not have the charger. Unsure how healthy the battery is. A+S keys broke off long ago, but you can still type on it if you hit the pads directly (I did that for over 2 years, so I can confirm you get used to it eventually). | Imgur: The magic of the Internet https://i.imgur.com/PbKVti3.jpeg | Yes |
Laptop - Dell Studio 1745 (Core 2 Duo T6600, 4 GB RAM, no HDD, working power brick) | Boots fine. Unsure how healthy the battery is. The top is undergoing rubber reversion, so do be mindful that it is a bit sticky and gross. (Will be wrapped prior to shipping to ensure the stickiness doesn’t rub off onto anything else.) | Imgur: The magic of the Internet https://i.imgur.com/kgPSHbX.jpeg https://i.imgur.com/J83EFSp.jpeg | Yes |
Laptop - System 76 Lemur Ultra (Lemu4; i5-3210M, 8 GB RAM, no HDD, working power brick) | Boots fine. Unsure how healthy the battery is. Comes with an optical drive conversion kit (so you can swap the DVD drive for a second 2.5" HDD/SSD). | Imgur: The magic of the Internet https://i.imgur.com/ukBATHm.jpeg https://i.imgur.com/Nbekz2d.jpeg https://i.imgur.com/zpKrZBz.jpeg | No |
Laptop - Lenovo ThinkPad R60 (IBM branded; unknown CPU, unknown RAM, no HDD, untested power brick) | A friend was trying to repair this but managed to rip the display ribbon cable (I don’t remember how), so he gave it to me, but I never got around to repairing it. I’m too scared to try and boot it now. Completely untested. | https://i.imgur.com/Aexcs3z.jpeg https://i.imgur.com/Ztjn9rH.jpeg https://i.imgur.com/9NsCVma.jpeg Imgur: The magic of the Internet | Yes |
Headphone Stand - Generic flimsy black plastic stand | It’s not the most stable stand, but it served me well for 6 years. Minor wear and tear. | https://i.imgur.com/o8lySPd.jpeg | Yes |
USB Hub - Rosewill 7-port Powered USB 2.0 Hub (working power brick) | Plugged a flash drive in to test it; it works. | https://i.imgur.com/xsS8O2D.jpeg https://i.imgur.com/WlFpeJq.jpeg Imgur: The magic of the Internet | No |
Optical Drive - ASUS DRW-24B1ST (CD & DVD R/W, SATA, untested) | I have no convenient way to test this, but it worked the last time I used it (5+ years ago). It’s been collecting dust ever since. | https://i.imgur.com/nc5q3SJ.jpeg https://i.imgur.com/GH6xGmq.jpeg https://i.imgur.com/1fvU7XC.jpeg | Yes |
I also have misc. cables, converters, and couplers (VGA, DVI, PC power cords, ethernet, SATA, etc.) for anyone interested, but I didn’t feel like listing them since I’m not actively trying to get rid of them.
