Hi My Hardware
ASUS PROART X670EAMD RYZEN 7900X 12 CORE64GB DDR5 4800MHZ RAM
Bios - Latest October, 2023
RESIZABLE BAR - OFFPCI Version 4PCI LANE BANDWITH X8 X8 for PCI 1 & PCI 2
Proxmox
Proxmox 7.4.-17 ***(i tried 8.1 same issue and rolled back to 7.4)***pve-manager/7.4-17/513c62be (running kernel: 5.15.131-2-pve)
Basically i have 2 X 4060,
GPU 1 on PCI 1 works fine,
GPU 2 on PCI 2 is unaccessble if i do vfio.
The gpu is not accessible at all forget about passthrough.
I have setup everything like blacklist and all
Grub - GRUB_CMDLINE_LINUX_DEFAULT=“quiet amd_iommu=on iommu=pt textonly nomodeset video=efifb📷ff video=simplefb📷ff video=vesafb📷ff”
vfio-pci 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem📷wns=none[ 84.589746] pci 0000:01:00.0: Removing from iommu group 13[ 84.609813] pci 0000:01:00.1: Removing from iommu group 13[ 84.609910] vfio-pci 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem📷wns=none[ 84.609913] vfio-pci 0000:03:00.0: can’t change power state from D3hot to D0 (config space inaccessible)[ 84.609973] pci 0000:03:00.0: Removing from iommu group 15[ 84.610007] vfio-pci 0000:03:00.1: can’t change power state from D3hot to D0 (config space inaccessible)[ 84.611607] pci 0000:03:00.1: Removing from iommu group 15
Please help.
I have a X570E ProArt which works fine.
Update: 1080 X 2 GPU (PCI 3) works fine strangely, one 4060 (first slot) and 1080 (second slot) also works fine
But as soon as the 4060 is placed in second slot, the above error comes again
