Upgrading NAS to 2.5 gbe
So I plan on upgrading my NAS to 2.5 gbe, but I’m noticing an issue with router’s.
Every router I’ve looked at only has one 2.5 gbe port so that seems to indicate I have to get a 2.5 gbe switch in order to get 2.5 gbe out of multiple devices.
Just curious if I’m right on this, but I find it really annoying becasue I’d rather just buy a router that is stacked with 2.5 gbe ports rather then having to add a switch to get the speeds I want between NAS and PC’s on the network.
I’m also wondering if traditional gigabit ports are a bottleneck for wifi 6.
My current NAS get’s around 100 MB to 125 MB speeds, but I’m trying to get it up to 150 MB to 250 MB which starts to hit the limit of my mechanical hard drives.
I’ll be putting m.2 drives in the NAS as well.
2 bay NAS with 2 m.2 drives for a total of 4 drives. The NAS will have two 2.5 gbe ports and two 3.2 gen 1 usb’s.
My main issue being that if router’s only have one 2.5 gbe port then it’s impossible to get 2.5 gbe speeds between NAS and a PC without a switch.
Yes, it’s annoying. Even more annoying are non wifi routers that color with a single 2.5Gbps WAN port and a single 1Gbps LAN (someone was showing a picture of such a thing somewhere on Reddit).
I’ve been using wifi 6 (not 6e) at home, and my devices can’t really do more than 700-800Mbps over WiFi with a U6-LR which has a gigabit port. I don’t think a gigabit port would be the bottleneck.
I think, any kind of service above 1Gbps is probably wasted if your consuming it primarily over WiFi (maybe not if have large home and multiple users on multiple access points simultaneously trying to use 1Gbps each, who would also be annoyed at each other when they only get 500Mbps each .. whilst downloading at the same time).
Maybe just bridge the two 2.5Gbps NAS ports, connect the PC to the NAS directly, and leave the other NAS port for your regular 1Gbps home LAN. This technically means your PC doesn’t have internet access while your NAS is rebooting, but how often does that happen?
Maybe you have been looking at the wrong products/your budget is not what these products cost (around 600USD router only, 800USD if you want gigabit)?
Coming soon, but going to be 800USD:
IMO we are still a couple of years away from standard high-end consumer routers having a whole set of 2.5g LAN ports on them paired with a 2.5+ WAN port. The market likes to drip feed features to get the most profit so you have something new every year. If they stuck the latest specs in all at once they would oftentimes have a dry spell for 2-3 years between worthwhile new advances.
Gigabit port won’t be a bottleneck for most wifi6, that was mainly an upgrade about efficiency with neighboring networks so that you can have less interference and thus better overall throughput. Wifi 6e does bottleneck a gigabit port easily though, and wifi 7 also will.
I don’t really think wifi 7 will be the driving force behind the router’s LAN ports getting an upgrade, as the wifi is built into these routers and thus wired ports won’t matter for it. I believe the driving factor will actually be internet speeds surpassing 1gb average in all largely populated areas. Right now this transition is starting to happen, with Comcast, Spectrum, and Fios all having cheap gigabit plans now, and also 2gb+ plans in many areas. There are plans for 5gb and 10gb internet speed rollouts in the next 3 years as well, and once that happens and 2gb gets pushed down to where gigabit is now ($50-60) we will finally see the LAN ports all get upgrades so that the speed can actually be used.
That is just my take on the landscape of things anyway.
Until those upgrades happen in the router, your only real option is a switch. Thankfully they have gotten very cheap the past year:
By “really cheap” @EniGmA1987 means 150 bucks for a 5 port … a bit meh. … I’d consider $20 for 5port 2.5Gbps to be really cheap - there’s no reason it won’t happen some day.
You can build your own x86 router with 4-6 2.5G ports for $200-$300 (Odroid h3+ and various topton/protectli/… units or diy am4 or intel if you don’t care about compact packaging)… then add wifi in the shape of whatever access point you feel like having. This is what lots of folks are doing, precisely because of 2.5G price gouging that’s going on.
Netgate 4100 doesn’t appear to be a router? I checked my xfinity router and it appears to have one 2.5 gbe port so I must be getting the best I can get from wifi 6 and my current router.
I would think that if I get a 2.5 gbe NAS, 2.5 gbe switch, and 2.5 gbe ethernet to usb-c adapter I should be able to push past 1 gigabyte speeds when transferring large amount’s of data between PC and NAS.
Huh?
The Netgate® 4100 with pfSense® Plus software is one of the most versatile security gateways in its class.
It combines the power of a Dual-Core Intel® Atom® C3338R Core CPU with integrated QuickAssist & AES-NI, and 4 GB of memory for a snappy user experience, delivering over 8.15 Gbps of L3 routing across six independent - (2) 1 GbE and (4) 2.5 GbE - flexible WAN/LAN ports.
The 4100 is actually more a router and less a switch, you will have to bridge ports in order to make it talk without needing the router part, and it will be less performant than a hardware switch at 2.5Gbps line rate
So yes, your original statement that there are a few consumer routers that also have a number of switched lan ports at 2.5Gbit is correct
The TP-link is going to address that, in a few months and for 800USD, that is still probably going to be a good value if it can handle the perfromance
You’ll know that only after trying it out .. if you nas can read data from storage fast enough then the theoretical upper ceiling is 2.3 Gbit/s (1 gygabyte/s is 8192Gbit/s so no, you won’t get that …)
If you already have the nas, the ISP modem/router with a singlle 2.5Gbps port, then your best budget option now is a QNAP QSW-1105-5T or a TL-SG105-M2 …
gotcha, thanks for the information
