upgrading my laptops graphics card wanted to double check compatibility here's a screenshot of SIW
http://i.imgur.com/AG6nT9n.png
and the card I'm buying.
http://www.ebay.ca/itm/NVIDIA-GeForce-GTX-670M-GDDR5-MX...
thoughts?
if you would like to see any other specs just request.
The 670M will certainly be an upgrade, the worry I have here is the power supply within the laptop. I don't know that much about PSUs in laptops but it would be well worth your while to check whether your computer will handle that new GPU.
