I’m in a bit of a situation right now. I had a system with a G4560 and recently bought a new GPU. It’s a Vega 56 (Sapphire Nitro+). I have a 1440p monitor (HP Omen 32) and I’m clearly bottlenecked in gaming.
The motherboard I have is the ASrock H110M-DGS. Its bios is updated so it can take a Kaby Lake CPU.
This is my dilemma right now:
Do I just buy an i7-7700 (or even 7700k, since I have the stock cooler from the G4560)?
Or do I buy a new B450 motherboard with an R5 2600X. (something like the ASRock Fatal1ty AB350 Gaming-ITX/ac)
I play all kinds of games, and I use Autocad and 3ds Max, but not professionally. I would also like to stream games (but mostly with AMD ReLive) and do audio recording (plug in my electric piano), and some light video editing of me playing.
I would very much appreciate your insights on how to proceed.
While that’s certainly true, I prefer to use a CPU that doesn’t have 80-90% utilisation when running game benchmarks, even it it is faster.
Also, four cores are almost obsolete nowadays since many new games use more cores efficiently.
@SapereAude1490 It basically depends on how much money you’re willing to spend. I’d pick a X370 board, but I also think that a B450 should be enough in terms of power delivery.
Personally I’d say buy a standard 7700 and be done with it.
It will do everything you want for now.
When it dies or becomes unusably slow, or you get more serious then you can upgrade.
For streaming with ReLive, for audio and for light video and autocad and 3ds max the 7700 for your existing setup is plenty. Autocad and 3ds max in particular currently suck in using non-intel multi core CPU’s.
I’m usually the first to advocate any AMD Ryzen CPU these days, but honestly you just don’t need it for what you want to do.
And going future proof on this setup for such a basic use case is a fools erand.
Buy the 7700 (doesn’t need to be K, (your H110 mainboard majorly sucks at Overclocking anyway), spend the rest to max your RAM. 2x 8Gb or 2x16Gb. 32Gb is max for your board.
And currently for 90% of gaming the 7700 will still exceed Ryzen 7 performance with little effort. Sure the 7700 it might sit at 90% doing it but when your GPU or even unused iGPU is doing the video capture to stream you wont even notice you’re missing the extra 2 or 4 more cores of a 2600X/2700X.
If you want to Go Ryzen now you’ll have to build essentially an entire new PC.
New Board, New CPU, New RAM(Seriously recommend Samsung B-die), and Probably new PSU. Likely even a new Case if your current case is a uATX only case. (Most B450’s are ATX boards)
The ASRock B350 ITX/AC is fine and basically the same board as the B450.
A Ryzen 5 2600 is 169,- bucks on amazon.com right now.
The ASRock board is less than 120,-.
You can literally buy both for less than a 7700.
@SapereAude1490 What memory do you have right now? Must already be DDR4.
Yikes. AMD has come far. Those are some good deals. Wish I had amazon here…
Where I am the 7700 is certainly cheaper than buying a new platform.
As regards to RAM though, If you have anything less than 2666MT/s RAM, I really recommend getting any other Dual Channel B-die RAM for Ryzen. In particular if the current RAM is Hynix-MFR type 2400/2133 he should change to at least 2666/2933 Samsung B-die for Ryzen.
2133/2400 Hynix-MFR RAM is truly terrible on Ryzen, not only is the latency in the low to mid 90 ns even with the fastest timings, the Fabric speed and overall system performance is not good. And if you’re really unlucky, several Corsair Hynix-MFR 2666 kits wont even POST/run stable with their XMP profile on lots of B350 boards.
Oh and @noenken I would avoid the ITX board if uATX also works, since uATX boards are generally cheaper than ITX.
Oh, yeah. If mATX is possible that opens up a lot more options. I thought the H110 board was ITX, my fault. I had a bad experience with an ASRock mATX couple weeks ago but that might have been a lemon. So yeah, that lowers the price even further.
