I recently had to reinstall my system. So I’m redoing all the gpu passthrough stuff. Following the guide I created the /etc/initramfs-tools/scripts/init-top/bind_vfio.sh script.
But that seems to make update-initramfs hang.
root@monolith:/boot/efi/loader/entries# mv /etc/initramfs-tools/scripts/init-top/bind_vfio.sh /root/bind_vfio.sh
root@monolith:/boot/efi/loader/entries# update-initramfs -u
update-initramfs: Generating /boot/initrd.img-5.4.0-7634-generic
cryptsetup: WARNING: Resume target cryptswap uses a key file
kernelstub.Config : INFO Looking for configuration...
kernelstub : INFO System information:
OS:..................Pop!_OS 20.04
Root partition:....../dev/nvme0n1p3
Root FS UUID:........e9a839d8-e38d-406b-a03d-337fcd7f154f
ESP Path:............/boot/efi
ESP Partition:......./dev/nvme0n1p1
ESP Partition #:.....1
NVRAM entry #:.......-1
Boot Variable #:.....0000
Kernel Boot Options:.quiet loglevel=0 systemd.show_status=false splash
Kernel Image Path:.../boot/vmlinuz-5.4.0-7634-generic
Initrd Image Path:.../boot/initrd.img-5.4.0-7634-generic
Force-overwrite:.....False
kernelstub.Installer : INFO Copying Kernel into ESP
kernelstub.Installer : INFO Copying initrd.img into ESP
kernelstub.Installer : INFO Setting up loader.conf configuration
kernelstub.Installer : INFO Making entry file for Pop!_OS
kernelstub.Installer : INFO Backing up old kernel
kernelstub.Installer : INFO No old kernel found, skipping
root@monolith:/boot/efi/loader/entries# mv /root/bind_vfio.sh /etc/initramfs-tools/scripts/init-top/bind_vfio.sh
This is all from today. But I had the update-initramfs -u running all night long…
When I look at other files in /etc/initramfs-tools/scripts, I see /etc/initramfs-tools/scripts/local-top/lvm-workaround has permissions of -rwxr-xr-t.
I tried setting the script to those permissions, but it didn’t help.
I also tried the 755 permissions mentioned in the guide first.
Using the -v flag gives a LOT of output. It stalls here:
Calling hook dmsetup
Calling hook klibc-utils
/usr/share/initramfs-tools/scripts/local-bottom/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/local-premount/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/local-block/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/init-top/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/init-top/brltty ignored: not executable
I’m assuming that’s about where it would grab the scripts out of etc.
I tried placing bind_vfio.sh in the /usr dir, but it didn’t help.
Any ideas?
