Not sure where to put this. Still new. FYI i could not get this version to run effectively on dual sparks. Claude Code and Codex said there wasnt enough room for KVM. Just to save you all a few hours of time. Im installing it for use with Hermes Agen on an old Dell XPS with Ubuntu.
LT
I wish I had 4 sparks, but it’ll probably still only be ~10t/s. Anyone got it running on 4 sparks? and if so what speed?
That is way too tight even on Q1. Just not worth it. You should consider minimax m3 which would comfortably fit on there at q3.
Apparently the answer was 30t/ and concurrency 4 at aggregate 60t/s for nvfp4 glm5.2 full not reap.
I got reap going 60t/s on 4x6000s
How did you fit nvfp4 on 4x600s? There is 47x10gb files. Are you offloading? Can’t if your getting 60t/s. Does it not load every single file?
Oh nm, i assume you used more cards on the FUL NVFp4
Testing “GitHub - JustVugg/colibri: Run GLM-5.2 (744B MoE) on a 25GB-RAM consumer machine — pure C, zero deps, experts streamed from disk. Tiny engine, immense model. 🐦 · GitHub”
370GB quant loaded in RAM, as a subagent, single tasker
EDIT: Not optimized to remian at 9.9GB, quickly decided to use over 30GB of RAM on a long response prompt.
