my Config:
Segate baracuda 8tb *3
Kingston 240gb *2 cache mirror
16gb ram
Core i5 3470
Dell mobo 042p49
Ethernet port 1gb
unraid v 6.90 beta22 ( ill explain)
docker image Mariadb (linuxserver)
docker image NextCloud(linuxserver) V19.0.0
Hi guys, i am new to unraid and new to this forum, so go easy on me.
i followed this guide to setup everything by [Spaceinvader One]( How to Setup Nextcloud on unRAID for your Own Personal Cloud Storage)
ISSUE:
so my issue is nextcloud Web upload is extremely slow. however when i mount the share as smb in windows 10: file upload is instant. and when i do this command for file scan to appear in nextcloud nothing happens. i have waited over 16hrs and nothing (after mover finished). i have about 500gb of data in my share folder now.
docker exec -it nextcloud sudo -u abc /config/www/nextcloud/occ files:scan Minerva
i googled around and it seems the problem is with nextcloud thumbnail generation ( at least what everyone thinks it is) and it looks like its an issues since v12.
Solutions i tried
old posts from reddit and github, people suggested to add this to nginx.conf
keepalive_timeout 10m;
proxy_connect_timeout 20s;
proxy_send_timeout 600s;
proxy_read_timeout 150s;
client_body_buffer_size 70m;
client_header_buffer_size 50k;
large_client_header_buffers 2 50k;
client_max_body_size 0;
it made it worse, now the web-client on upload crashes instantly.
this was the Original version of my nginx.conf
## Version 2018/08/16 - Changelog:
user abc;
worker_processes 4;
pid /run/nginx.pid;
include /etc/nginx/modules/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Logging Settings
access_log /config/log/nginx/access.log;
error_log /config/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
# nginx-naxsi config
# Uncomment it if you installed nginx-naxsi
#include /etc/nginx/naxsi_core.rules;
# nginx-passenger config
# Uncomment it if you installed nginx-passenger
#passenger_root /usr;
#passenger_ruby /usr/bin/ruby;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /config/nginx/site-confs/*;
#mail {
# # See sample authentication script at:
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
daemon off;
another solution i tried was the app from nextcloud appstore Preview Generator v 2.3.0 no help.
- i updated unraid to beta version in case that would fix anything but nope
Any Solutions ???
so any suggestions: do you think the issue is something else? idk what else to try anymore.
on a side note do any of you have experience with cozyio it seems it also like nextcloud but there is no docker image for it.
