I'm a bit confused about todays pricing of the UAP-AC (their first AC model for indoor use). When I check local stores and online auction sites it's notably more expensive than the newer models. Why is that? Any good reason why or just legacy pricing?
I can't really notice any difference between it and the newer AC pro models.
The old model is UAP-AC. Current models are UAP-AC-LITE, UAP-AC-PRO, and UAP-AC-EDU. I wouldn't get the lite version as it doesn't work with the standard 802.3af PoE.
