Undervolting my RTX 4090
Well, I have a new GPU and as usual i like to undervolt my things. So today marks the first daay of my tests and I would like to share them with you.
Regarding my test/verification setup I ran Port Royale with custom settings and Cyberpunk 2077 three times each and then compared the results:
Port Royale Cyberpunk 2077
Score Temp Power FPS Temp Power
Avg Max Min Max Avg Avg Max
Default Run 1 12140 67,2 452 472 49,48 93 74,24 63,2 396,2 410,711
Run 2 12164 67,4 452 472 52,79 107,92 74,02 63,2 398,5 410,711
Run 3 12183 67 451,55 475,8 35,48 107,81 73,94 65,2 399,8 416,237
Avg 12162,33333 67,2 451,85 473,2666667 45,91666667 102,91 74,06666667 63,86666667 398,1666667 412,553
vs. 985mV 1,0075 1,0184 1,1215 1,1062 0,8949 1,0355 1,0093 1,0127 1,1115 1,1127
vs. PT 70 - - - - 1,1387 1,0562 1,0339 1,0385 1,1963 1,2344
vs. PT 65 - - - - 0,886 1,0608 1,0583 1,001 1,2837 1,3266
vs. 60 FPS - - - - 0,7887 - - 1,0219 1,2619 1.1676
Score Temp Power FPS Power
Avg Max Min Max Avg Max Avg Max
2800Mhz @975mV Run 1 12048 65,4 - 416,117 - - - - - -
2800Mhz @985mV Run 1 12092 66,2 406,15 435,056 48,87 111,12 73,51 63,2 360 371,927
Run 2 ?? 66 403 429,71 58,1 97,81 73,19 63,3 358,4 372,785
Run 3 12085 66,1 400,9 426,024 49,87 96,25 73,14 60,2 352,3 366,875
Run 4 12045 65,5 400,75 423,865 55,53 99,63 73,52 63 359,8 370
Run 5 12074 66 403,15 421,142 59,42 99,6 73,93 64,5 359,5 371,445
Run 6 12065 66,1 403,45 431,142 36,07 91,91 73,02 64,2 359,3 371,84
Avg 12072,2 65,98333333 402,9 427,8231667 51,31 99,38666667 73,385 63,06666667 358,2166667 370,812
vs. Default 0,99% 0,9818 0,9817 0,904 1,1175 0,9658 0,9908 0,9875 0,8997 0,8988
vs. PT 70 - - - - 1,2725 1,02 1,0244 1,0255 1,0763 1,1095
vs. PT 65 - - - - 0,993 1,0245 1,0486 0,9885 1,1549 1,1924
vs. 60 FPS - - - - 0,8813 - - 1,009 1,1353 1,0495
2800Mhz @985mV PT 70 Run 1 - - - - 34,57 105,94 71,84 332,5 334
Run 2 - - - - 40,21 95,56 71,31 64 332,8 334,432
Run 3 - - - - 46,19 90,79 71,76 59 333,2 334,195
Avg #DIV/0! #DIV/0! #DIV/0! #DIV/0! 40,32333333 97,43 71,63666667 61,5 332,8333333 334,209
vs. Default - - - - 0,8782 0,9467 0,9672 0,963 0,8359 0,81
vs. 985mV - - - - 0,7859 0,9803 0,9762 0,9752 0,9291 0,9013
vs. PT 65 - - - - 0,7804 1,0043 1,0236 0,9639 1,073 1,075
vs. 60 FPS - - - - 0,6926 - - 0,984 1,0548 0,9459
2800Mhz @985mV PT 65 Run 1 - - - - 48,23 99,05 70,04 63,8 309,2 310,97
Run 2 - - - - 52,88 96,41 70,23 63,8 311,1 310,993
Run 3 - - - - 53,91 95,57 69,69 63,8 310,2 310,98
Avg #DIV/0! #DIV/0! #DIV/0! #DIV/0! 51,67333333 97,01 69,98666667 63,8 310,1666667 310,981
vs. Default - - - - 1,1254 0,9423 0,9449 0,999 0,779 0,7538
vs. 985mV - - - - 1,007 0,976 0,9537 1,012 0,8659 0,8386
vs. PT 70 - - - - 1,2815 0,9957 0,977 1,037 0,9319 0,9305
vs. 60 FPS - - - - 0,8876 - - 1,0208 0,983 0,8801
2800Mhz @985mV 60FPS Run 1 - - - - 58,16 61,98 60 62,5 319,3 353,339
Run 2 - - - - 58,55 61,48 60 62,5 312,7 353,339
Run 3 - - - - 57,95 62,22 60 62,5 314,6 353,339
Avg #DIV/0! #DIV/0! #DIV/0! #DIV/0! 58,22 61,89333333 60 62,5 315,5333333 353,339
vs. Default - - - - 1,2679 - - 0,9786 0,7925 0,8567
vs. 985mV - - - - 1,1347 - - 0,991 0,8808 0,9529
vs. PT 70 - - - - 1,4438 - - 1,0162 0,948 1,0572
vs. PT 65 - - - - 1,1267 - - 0,9796 1,0173 1,1362
The odd thing at 985mV is that the second test did not have any score so it might have failed which is an indication of an unstable undervolt.
I’m also wondering if I’m setting my curve the wrong way, because I’m trying a new approach. Instead of the classic one where one raises the clock at a given voltage I move the whole curve and lower everything after a specific voltage. The difference is that the former undervolts every clock setting, while the latter ramps up more towards the end. Maybe, the latter is preferable since power consumption and heat generation at lower clocks is negligible. Do you have any ideas/input?
The new approach undervolts every clock setting by the same amount. E.g. given an arbitrary but fixed voltage the clockspeed is bumped by n MHz.
GPU: MSI RTX 4090 Suprim X
CPU: 5900X
Mainboard: GIgabyte X570 Aorus Master
Edit (27.10.2022): I have updated the table and 985mV seem fine. However, Run 2 still bugs me and I also experienced a system freeze yesterday. This could have been caused by something else, but I’m still wary. I’m thinking of bumping the voltage by 5mV and test everything again. I assume the power consumption should roughly be the same but I should gain a bit stability just in case. Also, please note that somewhere between Run 4 - Run 6 Windows decided to install updates. I assume it was during the last Cyberpunk 2077 run (hence the low min fps) but I’m not sure.
Edit (30.10.2022): I have updated the table with additional information and came to the following conclusion: Initially, I wanted to test 2800MHz @990mV just to see the difference, but I was unable to set the clockspeed to 2800MHz. After testing with 985mV again I noticed that my GPU was also not able to reach 2800MHz, it was rather stuck between 2790Mhz or 2820MHz. While this difference would in practice be negligible it naturally has an effect on performance and power consumption.
Given that 985mV does seem to be stable is settled for this value for now and proceeded with testing Power Target limiting as suggested by der8auer and Optimum Tech. While it does further increase the power consumption of the GPU at a PT of 60% I noticed some peculiar behaviour which is why I aborted my tests and tested 70% and 65% instead. All values can be seen in the chart above.
However, I did come to a different conlusion as both YouTubers and I would not recommend reducing the PT of a 4090. Much rather, I would recommend limiting the FPS to something appropriate. For example, when capped at 60fps a 4090 uses 79% of the average power compared to default settings and is almost equal to PT 65% setting. Contrary to PT 65%, the frametime graph is almost a perfect line and much more consistent with lows being 13% higher. (It should be noted though, that peak power consumption is 14% higher than PT 65%, but still 86% of stock settings.)
Thus, I would recommend to undervolt a 4090 as much as possible and then proceed to limit the framerate to something appropriate.
Thanks for sharing. I always like seeing hard data.
For entertainment here is another guy trying undervolting the 4090:
Lol, who is that noob?!
I have updated the chart and added additional information.
I have updated the chart again.
