`$ sensors’ output:
amdgpu-pci-0600
Adapter: PCI adapter
vddgfx: +1.08 V
fan1: 704 RPM
temp1: +52.0°C (crit = +94.0°C, hyst = -273.1°C)
power1: 41.16 W (cap = 142.00 W)
`$ sudo lspci -v -s $(lspci | grep ’ VGA ’ | cut -d" " -f 1)’ output:
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X] (rev c7) (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited / Sapphire Technology Device e353
Flags: bus master, fast devsel, latency 0, IRQ 63
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at fe900000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150] Advanced Error Reporting
Capabilities: [200] #15
Capabilities: [270] #19
Capabilities: [2b0] Address Translation Service (ATS)
Capabilities: [2c0] Page Request Interface (PRI)
Capabilities: [2d0] Process Address Space ID (PASID)
Capabilities: [320] Latency Tolerance Reporting
Capabilities: [328] Alternative Routing-ID Interpretation (ARI)
Capabilities: [370] L1 PM Substates
Kernel driver in use: amdgpu
Kernel modules: amdgpu
`$ ls /sys/class/drm/card0/device/’ output:
ari_enabled current_link_width drm_dp_aux_dev i2c-3 local_cpulist numa_node pp_dpm_sclk pp_table resource2 subsystem_device
boot_vga d3cold_allowed enable i2c-4 local_cpus power pp_force_state remove resource2_wc subsystem_vendor
broken_parity_status device graphics i2c-5 max_link_speed power_dpm_force_performance_level pp_mclk_od rescan resource4 uevent
class dma_mask_bits hwmon i2c-6 max_link_width power_dpm_state pp_num_states reset resource5 vbios_version
config driver i2c-0 iommu modalias pp_cur_state pp_od_clk_voltage resource revision vendor
consistent_dma_mask_bits driver_override i2c-1 iommu_group msi_bus pp_dpm_mclk pp_power_profile_mode resource0 rom
current_link_speed drm i2c-2 irq msi_irqs pp_dpm_pcie pp_sclk_od resource0_wc subsystem
`$ uname -a’ output:
Linux "Redacted" 4.18.16-200.fc28.x86_64 #1 SMP Sat Oct 20 23:53:47 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
It appears to have dropped.
I also found this for anyone following along at home:
Thanks for the lead! So presumably I would `echo’ one of the listed values from that article into that file? I will look further into how compatible this will be with POLARIS cards.
Much appreciated. Any more input is very welcome!
Kind regards,
EDIT:
I’ve run the following & returned the below clock speeds:
`$ sudo cat /sys/kernel/debug/dri/0/amdgpu_pm_info’
GFX Clocks and Power:
1750 MHz (MCLK)
928 MHz (SCLK)
300 MHz (PSTATE_SCLK)
300 MHz (PSTATE_MCLK)
1000 mV (VDDGFX)
28.50 W (average GPU)
So I’m thinking if I run $ sudo echo "1" > /sys/class/drm/card0/device/pp_sclk_od
& $ sudo echo "0" > /sys/class/drm/card0/device/pp_mclk_od
I should get some positive results.
