I installed a GTX 1060 onto my server, and I’m trying to run Jellyfin via Podman, but I’m running into this issue:
This client isn't compatible with the media and the server isn't sending a compatible media format.
My server is configured as such:
- Ryzen 7 5700G
- GTX 1060 6GB
- 32GB RAM
- Ubuntu Server 22.04
Here’s the log:
[03:03:17] [INF] [99] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for yamiyuki. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
[03:03:17] [INF] [99] Jellyfin.Api.Helpers.MediaInfoHelper: StreamBuilder.BuildVideoItem( Profile=Anonymous Profile, Path=/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv, AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=Transcode, TranscodeReason=VideoCodecNotSupported, AudioCodecNotSupported ) media:/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/master.m3u8?MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&api_key=<token>&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported
[03:03:18] [INF] [22] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
[03:03:18] [INF] [22] Jellyfin.Api.Helpers.TranscodingJobHelper: /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -init_hw_device cuda=cu:0 -filter_hw_device cu -autorotate 0 -i file:"/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_nvenc -preset p1 -b:v 5296515 -maxrate 5296515 -bufsize 10593030 -profile:v:0 high -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(1920\,1080*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(1920/a\,1080))/2)*2,format=yuv420p" -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/config/transcodes/9fb210baa6fbb8db874cf990880df9f1%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/config/transcodes/9fb210baa6fbb8db874cf990880df9f1.m3u8"
[03:03:18] [INF] [96] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app Jellyfin Web 10.8.10 playing I Can't Suddenly Change. Stopped at 440397 ms
[03:03:18] [WRN] [96] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from https://jf.yamiyukisenpai.tech/Sessions/Playing/Stopped to 127.0.0.1 in 0:00:01.6484686 with Status Code 204
[03:03:18] [ERR] [94] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 1
[03:03:18] [ERR] [94] Jellyfin.Server.Middleware.ExceptionMiddleware: Error processing request. URL GET /videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts.
MediaBrowser.Common.FfmpegException: FFmpeg exited with code 1
at Jellyfin.Api.Helpers.TranscodingJobHelper.StartFfMpeg(StreamState state, String outputPath, String commandLineArguments, HttpRequest request, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource, String workingDirectory)
at Jellyfin.Api.Controllers.DynamicHlsController.GetDynamicSegment(StreamingRequestDto streamingRequest, Int32 segmentId)
at Jellyfin.Api.Controllers.DynamicHlsController.GetHlsVideoSegment(Guid itemId, String playlistId, Int32 segmentId, String container, Int64 runtimeTicks, Int64 actualSegmentLengthTicks, Nullable`1 static, String params, String tag, String deviceProfileId, String playSessionId, String segmentContainer, Nullable`1 segmentLength, Nullable`1 minSegments, String mediaSourceId, String deviceId, String audioCodec, Nullable`1 enableAutoStreamCopy, Nullable`1 allowVideoStreamCopy, Nullable`1 allowAudioStreamCopy, Nullable`1 breakOnNonKeyFrames, Nullable`1 audioSampleRate, Nullable`1 maxAudioBitDepth, Nullable`1 audioBitRate, Nullable`1 audioChannels, Nullable`1 maxAudioChannels, String profile, String level, Nullable`1 framerate, Nullable`1 maxFramerate, Nullable`1 copyTimestamps, Nullable`1 startTimeTicks, Nullable`1 width, Nullable`1 height, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 videoBitRate, Nullable`1 subtitleStreamIndex, Nullable`1 subtitleMethod, Nullable`1 maxRefFrames, Nullable`1 maxVideoBitDepth, Nullable`1 requireAvc, Nullable`1 deInterlace, Nullable`1 requireNonAnamorphic, Nullable`1 transcodingMaxAudioChannels, Nullable`1 cpuCoreLimit, String liveStreamId, Nullable`1 enableMpegtsM2TsMode, String videoCodec, String subtitleCodec, String transcodeReasons, Nullable`1 audioStreamIndex, Nullable`1 videoStreamIndex, Nullable`1 context, Dictionary`2 streamOptions)
at lambda_method758(Closure , Object )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfActionResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeInnerFilterAsync>g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Jellyfin.Server.Middleware.ServerStartupMessageMiddleware.Invoke(HttpContext httpContext, IServerApplicationHost serverApplicationHost, ILocalizationManager localizationManager)
at Jellyfin.Server.Middleware.WebSocketHandlerMiddleware.Invoke(HttpContext httpContext, IWebSocketManager webSocketManager)
at Jellyfin.Server.Middleware.IpBasedAccessValidationMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager)
at Jellyfin.Server.Middleware.LanFilteringMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager, IServerConfigurationManager serverConfigurationManager)
at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Jellyfin.Server.Middleware.QueryStringDecodingMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.ReDoc.ReDocMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Jellyfin.Server.Middleware.RobotsRedirectionMiddleware.Invoke(HttpContext httpContext)
at Jellyfin.Server.Middleware.LegacyEmbyRouteRewriteMiddleware.Invoke(HttpContext httpContext)
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
at Jellyfin.Server.Middleware.ResponseTimeMiddleware.Invoke(HttpContext context, IServerConfigurationManager serverConfigurationManager)
at Jellyfin.Server.Middleware.ExceptionMiddleware.Invoke(HttpContext context)
[03:03:18] [WRN] [94] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from https://jf.yamiyukisenpai.tech/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFgxMTsgVWJ1bnR1OyBMaW51eCB4ODZfNjQ7IHJ2OjEwOS4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzExOS4wfDE2OTkyMzI0ODM0Nzc1&MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&PlaySessionId=36c687d087fa42e78861841cae974efe&api_key=d8b8bd35b30248cda38fdfe788eede0f&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported&runtimeTicks=0&actualSegmentLengthTicks=30000000 to 127.0.0.1 in 0:00:00.629002 with Status Code 500
[03:03:18] [INF] [68] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for yamiyuki. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
[03:03:18] [INF] [68] Jellyfin.Api.Helpers.MediaInfoHelper: StreamBuilder.BuildVideoItem( Profile=Anonymous Profile, Path=/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv, AudioStreamIndex=1, SubtitleStreamIndex=3 ) => ( PlayMethod=Transcode, TranscodeReason=VideoCodecNotSupported, AudioCodecNotSupported ) media:/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/master.m3u8?MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&api_key=<token>&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported
[03:03:18] [INF] [86] Jellyfin.Api.Helpers.TranscodingJobHelper: Deleting partial stream file(s) /config/transcodes/9fb210baa6fbb8db874cf990880df9f1.m3u8
[03:03:18] [INF] [22] Jellyfin.Api.Helpers.TranscodingJobHelper: /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -init_hw_device cuda=cu:0 -filter_hw_device cu -autorotate 0 -i file:"/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_nvenc -preset p1 -b:v 5296515 -maxrate 5296515 -bufsize 10593030 -profile:v:0 high -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(1920\,1080*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(1920/a\,1080))/2)*2,format=yuv420p" -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/config/transcodes/57138e3f61c90b0ba37dcaf74c118ede%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/config/transcodes/57138e3f61c90b0ba37dcaf74c118ede.m3u8"
[03:03:19] [ERR] [99] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 1
[03:03:19] [ERR] [99] Jellyfin.Server.Middleware.ExceptionMiddleware: Error processing request. URL GET /videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts.
[03:03:19] [WRN] [99] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from https://jf.yamiyukisenpai.tech/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFgxMTsgVWJ1bnR1OyBMaW51eCB4ODZfNjQ7IHJ2OjEwOS4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzExOS4wfDE2OTkyMzI0ODM0Nzc1&MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&PlaySessionId=ecf85e3fca514066806e6ad9e7c8a819&api_key=d8b8bd35b30248cda38fdfe788eede0f&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported&allowVideoStreamCopy=false&runtimeTicks=0&actualSegmentLengthTicks=30000000 to 127.0.0.1 in 0:00:00.7266829 with Status Code 500
[03:03:19] [INF] [99] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for yamiyuki. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
[03:03:19] [INF] [99] Jellyfin.Api.Helpers.MediaInfoHelper: StreamBuilder.BuildVideoItem( Profile=Anonymous Profile, Path=/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv, AudioStreamIndex=1, SubtitleStreamIndex=3 ) => ( PlayMethod=Transcode, TranscodeReason=VideoCodecNotSupported, AudioCodecNotSupported ) media:/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/master.m3u8?MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&api_key=<token>&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported
[03:03:19] [INF] [22] Jellyfin.Api.Helpers.TranscodingJobHelper: Deleting partial stream file(s) /config/transcodes/57138e3f61c90b0ba37dcaf74c118ede.m3u8
[03:03:19] [INF] [22] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
[03:03:19] [INF] [22] Jellyfin.Api.Helpers.TranscodingJobHelper: /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -init_hw_device cuda=cu:0 -filter_hw_device cu -autorotate 0 -i file:"/media/DATA/SHARED/Videos/Anime/Isekai Quartet/Season 1/[KH] Isekai Quartet - 10 - Join In! Rivals.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_nvenc -preset p1 -b:v 5296515 -maxrate 5296515 -bufsize 10593030 -profile:v:0 high -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(1920\,1080*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(1920/a\,1080))/2)*2,format=yuv420p" -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/config/transcodes/b72257e33f6b0a01a136b0754667b8ca%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/config/transcodes/b72257e33f6b0a01a136b0754667b8ca.m3u8"
[03:03:20] [ERR] [91] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 1
[03:03:20] [ERR] [91] Jellyfin.Server.Middleware.ExceptionMiddleware: Error processing request. URL GET /videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts.
[03:03:20] [WRN] [91] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from https://jf.yamiyukisenpai.tech/videos/3b1b292a-6f4d-2dce-f412-fc0e8a6d1ee2/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFgxMTsgVWJ1bnR1OyBMaW51eCB4ODZfNjQ7IHJ2OjEwOS4wKSBHZWNrby8yMDEwMDEwMSBGaXJlZm94LzExOS4wfDE2OTkyMzI0ODM0Nzc1&MediaSourceId=3b1b292a6f4d2dcef412fc0e8a6d1ee2&VideoCodec=h264,h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&PlaySessionId=079463435a2848baab80a24002c2c2a8&api_key=d8b8bd35b30248cda38fdfe788eede0f&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=0fc0800fad93177275768434433062b3&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-level=51&h264-videobitdepth=10&h264-profile=high,main,baseline,constrainedbaseline&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported&allowVideoStreamCopy=false&allowAudioStreamCopy=false&runtimeTicks=0&actualSegmentLengthTicks=30000000 to 127.0.0.1 in 0:00:00.7241064 with Status Code 500
[03:03:20] [INF] [94] Jellyfin.Api.Helpers.TranscodingJobHelper: Deleting partial stream file(s) /config/transcodes/b72257e33f6b0a01a136b0754667b8ca.m3u8
[03:03:21] [INF] [97] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app Jellyfin Web 10.8.10 playing Join In! Rivals. Stopped at 0 ms
[03:03:21] [WRN] [97] Jellyfin.Server.Middleware.ResponseTimeMiddleware: Slow HTTP Response from https://jf.yamiyukisenpai.tech/Sessions/Playing/Stopped to 127.0.0.1 in 0:00:01.5143634 with Status Code 204
I installed NVIDIA Headless 535.
I followed steps here to getit placed in the Podman container:
- NVIDIA GPU | Jellyfin
- Installing the NVIDIA Container Toolkit — NVIDIA Container Toolkit 1.14.3 documentation
- Support for Container Device Interface — NVIDIA Container Toolkit 1.14.3 documentation
Here’s how I start Jellyfin via Systemd:
/usr/bin/podman run \
--cidfile=%t/%n.ctr-id \
--cgroups=no-conmon \
--rm \
--sdnotify=conmon \
--detach \
--label io.containers.autoupdate=registry \
--name jellyfin \
--publish 8096:8096/tcp \
--publish 8920:8920/tcp \
--publish 7359:7359/udp \
--device nvidia.com/gpu=all \
--security-opt=label=disable \
--device /dev/nvidia-caps:/dev/nvidia-caps \
--device /dev/nvidia0:/dev/nvidia0 \
--device /dev/nvidiactl:/dev/nvidiactl \
--device /dev/nvidia-modeset:/dev/nvidia-modeset \
--device /dev/nvidia-uvm:/dev/nvidia-uvm \
--device /dev/nvidia-uvm-tools:/dev/nvidia-uvm-tools \
--replace \
--userns keep-id \
--volume /opt/podvol/jellyfin/cache:/cache \
--volume /opt/podvol/jellyfin/config:/config \
--mount type=bind,source=/media,destination=/media,ro=false docker.io/jellyfin/jellyfin:latest
But it doesn’t appear to be getting used.
Any idea what I’m missing?
