Hi,
I am looking for UltraWide Free sync monitor but I am quite confused
like : IPS or VA/MVA or Quantum Dot
these are few :
Samsung S34E790C Curved Monitor 34 Zoll (86,36 cm) im 21:9 Format Auflösung 3.440 x 1440 Pixel (UWQHD), 2x HDMI 1.4, DP 1.2, USB 3.0
EUR 738,03
LG 34UM88 - Computer-Monitor der neuen Generation - mit Thunderbolt, Quick Charge, Dark Room Mode und vielen weiteren Features Der neue UltraWide Monitor 34UM88-P von LG steht mit seinen vielen neuen ...
EUR 599,00
Kindly suggest .. I am plan to buy it by end of March,
Thanks, Ripu Daman
The LG is a pretty decent one, I am planning to pick one up in the next weeks. I don't know about the other ones.
Do you really want it curved? If the only thing is gaming, then it will be fine. At the moment you actually need a straight line on that monitor you will realize, that curved isn't that great. But gaming wise and immersion is great... I rather go with LG than Samsung, but that is my personal experience with Samsung products in general.
Wait for freesync 2 certified ones imo
I want to wait for freesync 2 but I have to buy a dummy monitor as after Ryzen is released I will buy that and if no freesync 2 by then I have to go for something else.
501st
February 16, 2017, 10:20pm
7
Here's a good freesync ultrawide 1440p curved monitor from Korea:
M340CLZ 34" WQHD 3440x1440 100HZ AMD FREE Sync Curved Monitor in Computer, Tablets & Netzwerk, Monitore, Projektoren & Zub., Monitore | eBay!
Logan and LTT made a review about it:
I own this monitor. Here have another review.
I originally wasn't going to review this monitor as I thought Wendell was going to but turns out might be a while? So i'll do it myself! I will also attempt to point out specifications that are neglected to be mentioned from other sources. If you're here from somewhere else on the interwebs have mercy this is the first time i've reviewed something Here I have the Microboard M340CLZ 42-100hz (21-100 fps) freesync monitor Featuring a Samsung IPS panel [image] [image] Disclaimer, my vesa mount is modified see below [image] Is this monitor Vesa Compatible? eh... not really... See the hole pictured above? it's roughly 4mm too narrow for a standard vesa mount and some modification. additional screws are required, however, correctly located 100x100 screw holes are there! If you go the grind it down route, you will need 2 8-32x1/2 and 2 8-32x3/4 machine screws to screw it on.
It also comes with a metal stand (not pictured) it has the same finish as the edge of the monitor. it holds it a few inches off the desk, only adjustment is tilt.
The monitor has 1 DP 1.2 1 HDMI 2.0 and 1 DVI-D, DP is required for Freesync.
Here is a little video clip of Heaven to demonstrate freesync please pay no attention to color accuracy this camera is a POS. The color accuracy is perfect I assure you. Also note when the frame rate drop belows 42 to 41 or lower (effectively making the monitor go suddenly from 42 hz to 82 hz or lower) it does alright with the transition unless if it goes back and forth between for example 38 and 43 fps really quickly in which case it stutters momentarily, not sure if that's because of the monitor or driver related latency. Games that are not properly optimized (looking at you Ubisoft and EA) and stutter a lot can cause the monitor to ever so slightly flicker (or worst case scenario 1 or 2 black frames on occasion) in freesync mode. If you're running 1 graphics card i'd pretty much consider this issue to be ignorable, if you're running 2 like I am, jus…
501st:
M340CLZ 34
Thanks it all look good but the only disadvantage is if someone is shipping from outside EU there us 25% Duty, I bough a headphone from Massdrop so on that I have to pay 100$ more on 400$. This is 721 Euro so plus duty it will be 901 and Samsung is 934 .
