Well what joy, it’s nearly set up…and I find I can’t line the monitors up! The OCD in me, which I never thought I had, can’t cope with the 1/2 inch gap between the centre and side monitors
I also tried upside-downing the side arms, as they inclined from the central bar to the end of the arms. I needed to lower the side monitors so took a few bits apart and turned it upside down. It sort of worked, but now the arms flop around…so need velcro / selotape to keep still. so when I get the above mount, it should be OK…should!
Yes, I have a foot stool ‘borrowed’ from a friend Only downside to the table being around 1.5 inches off the wall (instead of the original 9), is that I don’t have enough space to stretch my legs out…first world problems
As it turns out, the adjustment I made, flipping the side arms so they hang down instead of up, gave me the vertical tolerance I needed. They’re still not perfectly symmetrical though, but that’s enough for one day!
800mm deep desk is strongly recommended, to think I started on a 450mm glass table, now that was terrible for leg room!
