Hello Level1
Been recently active on the forum helping some people with the header 127 bug and compiling the kernel to fix that bug. I have taken some time today to create a Python script that will download and compile the current kernel and apply the patch for you, currently this is for Ubuntu.
Only created a couple of scripts in my Linux journey, Enjoy my dudes
Created a script for Arch as well
Using your script as reference, I wrote a script to build a 5.2 kernel in debian 10 buster. I think it could be improved but I will leave it if you want to test it.
EDIT: retested script and removed unecessary packages, changed the way it writes the repo file and few tweaks. Script is runned with sudo ./NAME_OF_SCRIPT.py
#!/usr/bin/env python3
import os
import sys
import fileinput
import shutil
import time
##Variables
homedir = os.path.expanduser("~")
systemInfo = os.uname()
KernelVersion = '5.2'
KernelVersionPackage = '5.2.0-0.bpo.2-amd64'
PatchURL = 'https://clbin.com/VCiYJ'
SuffixKernelString = 'patched'
##Script Start
print ("This script will download and compile the latest linux")
input("Press ENTER to continue...")
##Enable backports
print("Enable backports build sources")
time.sleep(1)
#os.system("sudo /usr/bin/echo 'deb http://deb.debian.org/debian buster-backports main contrib non-free' > /etc/apt/sources.list.d/backports.list")
backportsfile = open("/etc/apt/sources.list.d/backports.list", "w+")
backportsfile.write("deb http://deb.debian.org/debian buster-backports main contrib non-free")
backportsfile.close()
os.system("sudo apt update")
time.sleep(1)
##Required packages
print("Downloading required packages")
os.system("apt-get -t buster-backports install build-essential libncurses-dev bison flex libssl-dev libelf-dev linux-image-"+KernelVersionPackage+" linux-headers-"+KernelVersionPackage+" linux-source-"+KernelVersion)
##Delete existing compiled kernel, and source folder, in case the script is being rerunned
os.system("rm -rif /usr/src/linux-*"+KernelVersion+"*.deb")
os.system("rm -rif /usr/src/linux-source-"+KernelVersion+"/")
##Extracting Kernel
print("Extracting kernel")
os.chdir("/usr/src")
os.system("tar -xvf linux-source-"+KernelVersion+".tar.xz")
##Applying Patch
os.system('clear')
os.chdir("/usr/src/linux-source-"+KernelVersion)
os.system("wget "+PatchURL+" -O /usr/src/linux-source-"+KernelVersion+"/pci.patch")
print("Applying kernel patch\n")
time.sleep(1)
os.system("patch -p1 < pci.patch")
time.sleep(1)
##Copy current config
os.system("cp /boot/config-"+KernelVersionPackage+" /usr/src/linux-source-"+KernelVersion+"/.config")
##Replace required line in debian config
for line in fileinput.input("/usr/src/linux-source-"+KernelVersion+"/.config", inplace=True):
if line.strip().startswith('CONFIG_SYSTEM_TRUSTED_KEYS='):
line = 'CONFIG_SYSTEM_TRUSTED_KEYS=""\n'
sys.stdout.write(line)
##Compile kernel
time.sleep(1)
print("Are you ready to compile the kernel\n")
os.system("make -j`nproc` bindeb-pkg LOCALVERSION=-"+SuffixKernelString)
##Install compile kernel
answer = None
while answer not in ("yes", "no"):
answer = input("Do you wish to install the kernel now?, Enter yes or no: ")
if answer == "yes":
os.system("dpkg -i linux-headers-*-"+SuffixKernelString+"_*_amd64.deb")
os.system("dpkg -i linux-image-*-"+SuffixKernelString+"_*_amd64.deb")
print("\nPlease reboot to apply changes and load the newly complied kernel")
elif answer == "no":
exit()
else:
print("Please enter yes or no.")
Thanks man, i will give it a test
Tried the script, getting errors
File "./Debcompile.py", line 45, in <module>
FileNotFoundError: [Errno 2] No such file or directory: '/usr/src/linux-source-5.2'
Strange I tested in a recently in a clena install on a vm and worked.
The command:
apt-get install linux-source-5.2
install the necessary file /usr/src/linux-source.tar.xz (on the script is executed on line 32) and the script should extract it on line 41. did the script installed that file ?
by the way how do you run the script ? I run with
python3 NAME_OF_SCRIPT
can you test that way ?
and not
python NAME_OF_SCRIPT
checked for the kernel in usr/src and there was no file, and for running it i did it as ./DebCompile.py and i set it to use python3
retested, made a few changes and edited the post. try it again with sudo ./NAME_OF_SCRIPT.py
