Heyya.
(SOLVED IN TERMS OF RUNNING BINARY)
Note from several updates - this is more turning up to be a oddball connected to the build methods of ethminer - with the combination of oddball of the AMD GPU PRO and OpenCL implementation connected to it…
(Converting this to a trial-and-error-thread-please-assist-if-you-want-thread, in case someone else ends up with the same issues…)
Been trying this morning and over lunch to smack the AMD GPU PRO drivers with OpenCL onto my Ubuntu 20.04 machine (Yes… I need that or at least something that fires off OpenCL). Reason, running ethminer.
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
Backstory would be that I want to play with mining. I’ve targeted ethermine since it was a breeze to get running with my Nvidia-cards and CUDA.
However, it’s not a walk in the park with the AMD portion.
Standard packages, even adding on some that’s already in the standard repo will error out (well, ethminer 0.18/0.19 will -
input.cl:321:9: error: implicit declaration of function 'amd_bitalign' is invalid in OpenCL
input.cl:180:9: note: expanded from macro 'KECCAK_PROCESS'
input.cl:99:60: note: expanded from macro 'KECCAKF_1600_RND'
input.cl:87:24: note: expanded from macro 'ROTL64_1'
input.cl:433:5: error: implicit declaration of function 'amd_bitalign' is invalid in OpenCL
X 17:09:04 cl-0 OpenCL kernel build error (-11):
clBuildProgram
SIGSEGV encountered ...
stack trace:
backtrace() returned 7 addresses
./ethminer() [0x422af9]
/lib/x86_64-linux-gnu/libc.so.6(+0x46210) [0x7f4696527210]
./ethminer() [0x6e0a61]
./ethminer() [0x4baff6]
./ethminer() [0x773aaf]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x9609) [0x7f4696846609]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f4696603293]
pure virtual method called
terminate called without an active exception
Aborted
So, of course I did some google-foo, and ended up with the ‘latest’ AMD driver for my RX580. (20.45 at time of writing) - actual install-params was headless and pro…
https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-580
However, compiling the dkms-component explodes… (usually, all explodes but dkms-components triggers it…)
$ uname -r
5.8.0-43-generic
After som mashing - I’ve managed to “partially” get it right, (it’s a looong time banging on it and ended up removing for no real reason most of the other stale kernels and reinstalling 5.8.0-43
apt-get install --reinstall linux-image-$(uname -r) linux-modules-$(uname -r) linux-modules-extra-$(uname -r) linux-headers-$(uname -r)
Now, it got a bit more happy - but, the first error is back (instead of just "can’t find a proper gpu to use…).
$ dkms status
amdgpu, 5.6.20.906316-1188099: added
There’s a long threat I found that goes back a while with the 5.4 Kernel of Ubuntu 20.04,
Last entry confused me quite a bit…
In short - does anyone sit on any kind of pointers?
I thought the fighting drivers-days were over, but … wrong I was…
(OpenCL … really… this much trouble?)
Odd part - clinfo does print out statements… Perhaps it’s just the software I am trying to run that has the real issues?
clinfo
Number of platforms 2
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.1 AMD-APP (3188.4)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Platform Host timer resolution 1ns
Platform Extensions function suffix AMD
Platform Name Clover
Platform Vendor Mesa
Platform Version OpenCL 1.1 Mesa 20.2.6
Platform Extensions function suffix MESA
Number of devices 1
Device Name Ellesmere
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 1.2 AMD-APP (3188.4)
Driver Version 3188.4
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Board Name (AMD) Radeon RX 580 Series
Device Topology (AMD) PCI-E, 09:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 36
SIMD per compute unit (AMD) 4
SIMD width (AMD) 16
SIMD instruction width (AMD) 1
Max clock frequency 1386MHz
Graphics IP (AMD) 8.0
Device Partition (core)
Max number of sub-devices 36
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x1024
Max work group size 256
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple 64
Wavefront width (AMD) 64
Preferred / native vector sizes
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 8584028160 (7.994GiB)
Global free memory (AMD) 8360936 (7.974GiB)
Global memory channels (AMD) 8
Global memory banks per channel (AMD) 16
Global memory bank width (AMD) 256 bytes
Error Correction support No
Max memory allocation 7072877363 (6.587GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 2048 bits (256 bytes)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 128
Max number of write image args 8
Local memory type Local
Local memory size 32768 (32KiB)
Local memory syze per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 7072877363 (6.587GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Prefer user sync for interop Yes
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 1613486669118414579ns (Tue Feb 16 15:44:29 2021)
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Thread trace supported (AMD) Yes
Number of async queues (AMD) 2
Max real-time compute queues (AMD) 0
Max real-time compute units (AMD) 0
SPIR versions 1.2
printf() buffer size 4194304 (4MiB)
Built-in kernels (n/a)
Device Extensions cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_amd_bus_addressable_memory cl_khr_spir cl_khr_gl_event
Number of devices 1
Device Name Radeon RX 580 Series (POLARIS10, DRM 3.38.0, 5.8.0-43-generic, LLVM 11.0.0)
Device Vendor AMD
Device Version OpenCL 1.1 Mesa 20.2.6
Driver Version 20.2.6
Device OpenCL C Version OpenCL C 1.1
Device Type GPU
Max work item sizes 256x256x256
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 0 / 0 (n/a)
float 4 / 4
double 2 / 2 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Denormals No
Round to zero No
Correctly-rounded divide and sqrt operations No
Denormals Yes
Round to zero Yes
Global memory size 8589934592 (8GiB)
Max memory allocation 6871947673 (6.4GiB)
Alignment of base address 32768 bits (4096 bytes)
Global Memory cache type None
Image support No
Max number of constant args 16
Max constant buffer size 2147483392 (2GiB)
Queue properties
Profiling Yes
Profiling timer resolution 0ns
Device Extensions cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [AMD]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
Starting to look very much like the build of the binary I am trying to run has some serious issues and has hard AMD OpenCL binary that creates the scenario - I am trying to put my head into building it myself and will either kill this thread if I can figure out that it is the cause, or just see if it’s a joint issue…
(ethminer project link;
Release ethminer 0.18.0 · ethereum-mining/ethminer · GitHub )
Issue created at;
Issue cleared, as far as compiling and running it goes.
As always - thank you Arch Linux users, your documentation is amazing.
https://wiki.archlinux.org/index.php/AMDGPU
This means that after cloning the ethminer repo, and not just downloading the “source” compressed files, compiling works. What I used what to kill off the AMD binary included (and turned off CUDA).
So far final words:
I see this still as a problem but not actively looked at. There’s major issues with AMDGPU Pro as we know. Resolving this lies in the hands of AMD.
Developers going the partially great and partially lazy-turtle route will make things really hard. Including other git repos and forcing an init on those repos before building is just for me awkward. The AMD binary includes (to be dug out as far as I am capable) is an issue for ethminer.
I hope you all can get some useful information from all this.
Thank you for reading :).
