Hi all,
This will be my first time jumping into learning and playing with fiber networking.
I’m looking to buy the following hardware:
Ubiquity USW-Aggregation 10GE Switch
TP-Link TL-SG1218MPE Switch
The Unifi controller will be a docker container on a 1Gbs RJ45 connection.
A crude diagram:
USW-Aggregation 10GE SPF+ ------> TL-SG1218MPE 1GE SPF -----> 1Gbs RJ45 unifi controller.
A crude diagram of my question:
USW-Aggregation 10GE SPF+ —(What do i need to use for this connection)—> TL-SG1218MPE 1GE SPF -----> 1Gbs RJ45 unifi controller.
My Question:
While doing research, I found that the USW-Aggregation Switch does not auto-negotiate 10GE to 1GE SPF correctly so adopting the switch to the Unifi console for the first time is a headache, as for the USW-Aggregation to work correctly at 1GE, you need to set that manually for each port via Unifi console.
So how would I go about adopting the USW-Aggregation switch on a 1Gbs network?
I found 1 post on the ubiquity forums:
How to add a 10G only switch (USW AGG) into an 1G only network
where the gentleman eventually got the switch to connect to his 1GE switch using the following SPFs:
UB-UF-MM-1G
But from the tone of his post It was more of a lucky situation that it worked for a while for him to adopt it and then manually set the port to 1Gbs.
I am struggling to understand how to connect and adopt the switch.
Is there perhaps a DAC cable from Ubiquity that does the auto-negotiation that I need to get (SFP+ to SFP)
or
would it be better to get a smaller 10GE with 1Gbs RJ45 ports switch for seamless connection eg a TL-SX3206HPP.
Just a quick notice, were I live, it is extremely difficult to get all Ubiquity and fiber base networking products in general. So getting a base understanding would be awesome, from there I can see what hardware I can purchase that will do the trick.
eg I can’t get the (UB-UF-MM-1G SFP) from the above mentioned post.
Thank you and sorry if my question is ignorant, I’m struggling to understand how it works with out being able physically play with fiber yet.
