I’m not a complete network rookie, but the certificate I have to prove that, I took nearly 10 years ago.
So, a buddy of mine wanted help improving the networking situation at a local resturant/concerthall, (no idea what it is, they play music and serve food, occasionally standup and maybe an odd lecture, but also have live concerts). He had already tried himself, and he’d gotten another local guy to try. Both of whom failed.
I figured I could do it.
I could not.
It’s a private network that never needs to connect to the internet.
They have two pieces of audio gear that needs fixed IP addresses, and they must connect to the router with cable. Then they want an accespoint for a handful of tablets and phones for staff/technicians. Everything has to be on the same subnet.
I was given two pieces of gear to work with.
1 EdgeRouter PoE router to work as, I guess switch?
1 NanoStation M5 to use as wireless accespoint.
I’m aware that the above are odd choices for gear, but I had no hand in picking them out. I’ve just been tasked with getting them to work.
I’ve been poking at it for a few hours but ended up getting frustrated. The web interface straight up crashed and I’ve been unable to re-log onto the Router, seemingly for no reason. And logging back in required a reset of the device, making any changes a wasted effort. Partly I suspect bad cable or something. Also the Router gets hots, not too hot to touch, but close.
What I tried/how far I got.
Router:
I enabeled PoE on eth4 to power the NanoStation, that works fine.
I enabeled the Router to be a DHCP server, to hand out some IP’s. I assume it works but I can’t really test it.
I switched ports 2, 3 and 4 because I don’t think I need it to route between the same subnet, right? I want 2 and 3 to be the audio gear.
Accespoint
I’ve also, sort of, setup the NanoStation as accespoint.
Wireless is set to be an accespoint.
SSID is hidden, WPA 2/PSK, and I think AES encryption. However when I attempt to connect to it, wirelessly, I’m getting a security error. Not sure why, both my phone and win7 laptop wont connect to it.
For Lan settings I set it to be a bridge, not sure this is correct.
I know there must be setting I’ve gotten wrong, probably something simple. Any advice will be much appreciated. Step by step guide would be helpful, but I suspect I’d learn more from crashcourses on what I need to know.
I’ll be happy to elaborate and clarify, but for now I want to look at something tha isn’t the webinterface.
Thanks in advance.
PS, I’m not really in a hurry as I’ve borrowed the router and the accespoint until I can sort it out.
