After Wendell tipped us all off about the used enterprise U.2 drives entering the market recently, I decided to try my hand with one of the 3.7TB Huawei Dorado drives. I’ve connected it to the system with a PCIe adapter but I’m having a lot of trouble getting anything onto it. It looks like the previous owner /dev/zero 'd the whole thing or it’s mostly dead, but I can’t work out which. I thought I’d make a thread to chronicle my struggles since I can’t find much about this kind of stuff on-line. Any help from someone smarter or more experienced than I am would also be appreciated. And so, what I’ve tried so far:
The device shows up with lsblk, but not fdisk -l. All superblocks appear to be missing. I’m not entirely sure what a superblock is.
mkfs /dev/nvme0n1 failed to create a filesystem, I’m now thinking there are some bad blocks on the disk.
I’m running badblocks /dev/nvme0n1 right now, I’ll report back with results when it’s finished.
Okay, well, I guess I wasn’t much help I guess if badblocks is working, then that’s something?
Maybe see if gparted gives a popup with advice, if it sees it? I’ve always found it to be pretty verbose for a gui app
you mean no internet to download gparted? maybe parted is installed?
I’m afraid I haven’t had to do anything low level except the occasional secure erase.
Wendell did a thread about changing the sector size on enterprise drives, maybe a few steps in that might help you out? like the first few bits?
