I am buiding a workstation with S8030 + EPYC 7443P got the error message like this:
The bmc works and when I login not error messages…
It that because the board do not support 7003 by default? Should I upgrade BIOS ? The default BIOS version is 3.0 which is very old. I can do bios upgrade in BMC but I do not know which file shoud upload to the ui:
I download the BIOS zip file from TYAN website . Should I upload the zip to the UI or should I pick one file after unzip?
I see a topic [Tyan S8030 Firmware Update issues] which is similar with mine, but I dont get the answer there.
