Turnstone for 5G Threat Hunting? Need help
Hi everyone :slight_smile:
I’m working on a project that involves sifting through >400GBs of network logs from a simulated 5G core environment to look for indicators of attack and/or signs of compromise.
I’m trying to utilize TURNSTONE to augment a local LLM with tools and MCPs to help with this.
I’ve never dealt with network logs of this scale or done formal threat hunting work before so I’d like some guidance on if what I’m doing is even sane and if there is a better/smarter way to go about it.
Some important details:
• R7 5700X, 32GB DDR4 , 9060 XT 16GB (it is what it is…)
• Currently using Gemma 4 12B for the LLM
(pls feel free to suggest models that might work better for this task)
The logs are split as follows:
• 400+ GBs of .pcap files (over 30 000 files).
• ~40 GBs of .ndjson logs (about 8 files e.g. amf_log, smf_log, kubernetes_log, syslog, etc.)
Here’s a chart of my crazy contraption (plan).
The idea so far is:
#1
• Get a local LLM to “scan through” the logs with targeted queries using a tool like DuckDB.
• Isolate suspicious events (e.g. numerous authentication failures) and their timestamps.
• Output those results into a .gexf format file.
#2
• Load this into Gephi Lite (browser-based data/network visualization).
• Correlate the findings from all the individual logs.
• Either output a summary from Gephi back into Turnstone or manually type out an analysis and provide that as additional context for the LLM.
#3
• Instruct the LLM to go look for “evidence” in the .pcap files using tshark and specific timestamps based on previous analysis (e.g. Look for packets transmitted from 10.79.132.14 within X time range).
I’ve managed to get some promising output for the first third of the plan.
However, formatting the output into data that is not only compatible with Gephi but also provides meaningful representation (instead of random IPs going all over the place) has been difficult. There are so many columns and data points to normalize for it feels like…
The final third of the plan involving tshark should be relatively easy but thinking about judge models, skills, the Gephi format… is a bit overwhelming.
Appreciate thoughts and advice.
