Is it bad for the hardware if you turn of the power supply almost avery night after you shut down your pc?
nothing should happen to the Computer if you turn off the power supply as you're just taking away the power to it, which your computer should work fine just sitting there until it needs to be turned on again for use, a Computer doesn't need to have constant power until it's Turned on.
If you shutdown the computer through windows->shutdown, and then turn off the PSU once the computer is shutdown, it should be alright.
I'd be wary of you doing a force shutdown by killing the PSU, though.
