Trying to do IP Passthrough from PPPoE to a downstream device
I have a Unifi Cloud Gateway Ultra, and my ISP uses PPPoE for authentication. Recently, Unifi pushed a bad update that broke PPPoE and now my internet speeds are only 140mbps instead of the gigabit speeds I used to have. My ping is also much higher than before.
I have already tried downgrading the Unifi gateway, but after multiple attempts using different strategies, different backup files and different versions all failed, I don’t want to go down this path any further.
ChatGPT suggested putting a router between my modem and my Unifi gateway, and have that router handle PPPoE then hand the IP obtained from PPPoE to my Unifi gateway. I tried to do that on a Mikrotik RB750Gr3 but I can’t find any information on how to do such thing. ChatGPT and Gemini both gave invalid configs that won’t apply.
ChatGPT also suggested the TPLink ER605 as an alternative to Mikrotik but I am hesistant to pull the trigger.
I am out of ideas and want a solution to get back my internet speeds without needing to reconfigure everything.
Constraints:
  • Budget of $150 if additional hardware is needed
  • The Unifi gateway should remain my primary router
  • The Unifi gateway should not be asked to do PPPoE
  • The Unifi gateway should have the public IP from PPPoE on its WAN interface (otherwise some things I have configured will break)
  • Everything is powered off a UPS so efficiency should be taken into consideration
Networking gear I have laying around:
  • Mikrotik RB750Gr3 (given by friend for free)
  • Some unmanaged switches
I’d say try this again, but do so manually following the wiki:
Instead of downgrading your UniFi Cloud Gateway Ultra, have you tried fixing the update that broke PPPoE? If you’re interested, I can provide the instructions that should repair the update.
If you continue with your current plan, you will probably end up with a double NAT network stack. While that isn’t the end of the world, it can make sharing services with the internet more difficult than it needs to be.
Also, once you get the MikroTik RB750Gr3 configured correctly, if you still want to use the Cloud Gateway Ultra you will likely need to factory reset it anyway before putting it back into your network.
For what it’s worth, my network stack is currently double NATed as well because I’m sharing a single internet connection between two separate networks.
Hi there,
Putting another device in front will work. You can configure the WAN port in Unifi not to masqerade. That avoids double NAT.
I run PPPOE on 5.0.16 (ipv4) and do not have performance issues. I get 3G up and down. I use the IDS but I do not use Smart Queues or QOS as thats not supported for hardware acceleration. 5.0.10 seemed to enable it but was flakey for some hence why it went back.
Also the on the UCG Fiber ports matter. Port 6 and 7 always seems to work, port 5 seems according to reports to sometimes not get full speed. Other ports are fine.
Hth
