Trx50 Asus sage WiFi and Expo Ram setting
Hello everyone,
some might remember my recent built here
I was just updating the Bios to the latests version and thought, ok, lets give that Expo Ram preset a first try.
So I just selected it in the Ram settings in the Bios, and got the infamous CPU warning from AMD/Asus…
I pressed Y.
So Am I good to go with just that selection of that Expo profile? Or do i need to activate somethingelse like
PBO?
I obviously am a complete novice with such stuff. So all I want for now is my Ram running at 6400.
Checking Hardware Info and other tools, I see it does now.
Not sure if That’s all there was to do?
Also, performance tests now are giving better results!
Anyway, If you have advice here, please let me know :slight_smile: thank you
Hi!
I have the same motherboard. Afaik you just enabling the Expo settings indeed at Advanced → AMD Overclocking → Accept → DDR → DDR Options → DDR Timing Configuration → EXPO - Enable. And select the EXPO profile accordingly.
The EXPO profile should do all the magic for you, according to the memory profile from the memory you bought.
For example: I have Kingston FURY 128 GB DDR5-6400 sticks. Which has two profiles to select from: Profile 0 - DRR6400 and Profile 1 - DDR6000. Then save the settings via F10. And finally you need to “avoid your warranty” by pressing ''y" (yes to accept).
I’m personally a bit shocked I need to void my warranty by just only enabling EXPO… Is that even legal in the EU?!?
Regards,
Melroy van den Berg
