So my issue is that truenas only detect ones hdd of my 5 bay direct attached storage. I went onto truenas forum and they are very elitist. They wont answer and say I am stupid for trying to use a usb nas. Thing is I have all 8 bays of my nas filled up so i am trying to expand with addition usb enclosure.
Anyways truenas is only detecting one of the 5 drives. I had them previously in a synology. So I know they still work.
Any idea?
I am using the above model. It has built in raid, but I am running it without raid. So basic disks.
I’m not sure I would go as far and say they’re very elitist because you’re not getting the answer you want. USB is a poor choice for continuous/permanent storage in general due to reliability issues but it can work. Have any of you tried using eSATA instead? SATA PM (Serial ATA port multiplier) which I assume it uses may not however be supported by all controllers. From what I recall Intel don’t and only some AMD do, ASMedia controllers also works fine in most cases.
They want it the right way or no way at all.
If you are okay with some risk and not being 100% uptime, it can work fine.
I run Windows as host os and then Truenas as a VM and pass in the drives.
Been working fine for me.
