Is there another way to accomplish what my goal of rebalancing my VDEVs? They are pretty whacked out right now, as I’ve added two new VDEVs in the past year or so.
I commented out lines 60 and 61 so I don’t have progress tracking, but it seems to be working fine. Just wondering if I could accomplish the same result a better way.
Pacman is the package manager for Arch linux, so that won’t work on Truenas.
The bc command is a simple calculator. If you want to install it you’ll need to do this through whatever package manager truenas has.
Also TBH I wouldn’t worry about rebalancing your pool. Only workloads with lots of random reads like databases would really benefit from it. Large media files are sequential and generally buffered, so they can be read easily with large sequential reads.
But in any case, I hear you. What’s also nice, is that it should also work such that metadata that is current stored only on the spinning disks will get “moved” to my SPECIAL VDEV. So, really, it’s usefulness is twofold.
