I am trying to setup replication between 2 TrueNas SCALE hosts. Due to networking limitations, the backup target will be the side initiating the tasks.
The datasets I am trying to backup are all datasets in my Data pool (/mnt/Data)
Whenever the replication tries to start, it fails with this error:
[2023/05/27 10:08:01] INFO [Thread-33] [zettarepl.paramiko.replication_task__task_1] Connected (version 2.0, client OpenSSH_8.4p1)
[2023/05/27 10:08:01] INFO [Thread-33] [zettarepl.paramiko.replication_task__task_1] Authentication (publickey) successful!
[2023/05/27 10:08:03] INFO [replication_task__task_1] [zettarepl.replication.pre_retention] Pre-retention destroying snapshots: []
[2023/05/27 10:08:03] INFO [replication_task__task_1] [zettarepl.replication.run] For replication task 'task_1': doing pull from 'Data' to 'Data' of snapshot='auto-2023-05-27_18-00' incremental_base=None include_intermediate=False receive_resume_token=None encryption=False
[2023/05/27 10:08:03] ERROR [replication_task__task_1] [zettarepl.replication.run] For task 'task_1' unhandled replication error ExecException(1, "cannot unmount '/var/db/system/rrd-40cc91dacae0491e84781ab81ded8ba4': pool or dataset is busy\n")
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 181, in run_replication_tasks
retry_contains_partially_complete_state(
File "/usr/lib/python3/dist-packages/zettarepl/replication/partially_complete_state.py", line 16, in retry_contains_partially_complete_state
return func()
... 9 more lines ...
ReplicationProcessRunner(process, monitor).run()
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 33, in run
raise self.process_exception
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 37, in _wait_process
self.replication_process.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/ssh.py", line 159, in wait
stdout = self.async_exec.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/async_exec_tee.py", line 104, in wait
raise ExecException(exit_event.returncode, self.output)
zettarepl.transport.interface.ExecException: cannot unmount '/var/db/system/rrd-40cc91dacae0491e84781ab81ded8ba4': pool or dataset is busy
Is there any way to fix this?
