I am helping a colleague of mine to troubleshoot a workstation build. And I would appreciate any inputs from you folks. As I am quite puzzled.
The system in question has the following parts.
Intel i7 5960x
Asus X99-E WS Motherboard ( bios version 3004)
128gb (32x4) Memory (Crucial)
Nvidia GTX 1080
Currently, the system posts and everything shows up on the BIOS. We also use the hardware detection tool that came with the arch-linux iso to double check.
Here's the problem though, once we tried to boot into an os ( Ubuntu and Arch) it just freezes. This is with the kernel flag "nomodeset" added.
Apart form that I have not been able to decipher whats causing this?
I did find some incompatibility using the asus website. Which says that the CPU version needs the bios 0413.
If the bios is not compatible? Shouldn't it be not posting?
@anon85933304 asus now says it supports 128Gb so like @SocksNSandals it may need a bios update which is easy peasy on asus stuff you should update your friends bios @feverDream it seems like the only outliar here
For sure. I have same mobo and CPU. Just 64gb but it does support 128gb. Ubuntu will boot ok for me but I have video issues so I ditched Linux on that box.
The bios listed on the website is just the minimum for that CPU to work- that was the first version that would allow a 5960x. Use the newest. Definitely use a single ram stick to test and run it with NO OC. this board doesn't OC well.
Did you check the switch on the board to see what the lanes are set up to? I know on my Deluxe you need to set how the lanes are set up via a switch on the bottom of the board. (might not be enough lanes on default setting for 3rd gpu)
