Ok i started overclocking my gigabyte 7870. i increased the core clock on AMD Overdrive and it showed up on GPUZ but when i go to the sensors it says the max it gets is 1100mhz (the stock clock) and on heaven their is the clock speeds in the top corner and it shows my stock speeds. Am i missing something because when i try and boost the core clock it stays at stock.
That is strange. Have a sapphire 7870, and heaven shows correct clocks for me. I did notice that profiles will get messed up if you have ccc/sapphire trixx/msi afterburner open at the same time. If you are getting slightely higher scores when changing clocks I would write it up as a bug.
Well this is very confusing because this card is not voltage locked. http://gyazo.com/42e8e0819d99ade3060514fc63eb62df Here is a screen cap of my overclock. (it's minor because i am testing) and it shows the max speed it got in in GPUz, my max speed on msi afterburner was stock too. WTF.
You can try but i doubt it will actualy change the voltage on the card as i sead GB cards are locked down preity hard on the voltage as thay useualy use stock reference pcb's.
Have you got a screen cap of overdrive from the catalyst control center?
