I'm posting this here because I don't know for sure what to buy and what to look for, from what I understand I need to get the ones with IPS panels because they're better. Is there any difference if one monitor is 8MS and others are 5?
The monitors will be connected to a laptop that has 1x VGA port ; 1x HDMI port; USBs. I hope I can get 1 connected to each port available and leave the rest of USB for keyboard mouse and microphone.
Are you sure that your laptop is able to use both outputs simultaneously? Also, you only list having two display outputs. Where are you going to hook up the third monitor?
If my laptop cannot handle it, I will buy a new computer and will keep only the 27' until it arrives.
my laptop currently runs on 2 x 1080p monitors right now, it's kinda like a workstation that I use daily
@aezen, can I plug the 3rd monitor thru usb? Sorry, I'm noob :(.
Also I was hoping to get more opinions on the monitors, are the 3 that I chose ok?
I want them to be perfect size, to be same height and also the colors and luminosity to be the same, so I went with same brand of monitors Dell and same generation.
