I currently have three VGA monitors which I’m looking to get a triple monitor mount for. I’m wondering what you can recommend. Right now, I have my eye on this one from Planar that’s currently listed on Newegg.
monitor size? wall mount? table mount? stand? whats the desk look like and how straight and level is it? if their are only 3 you may want 3 individual monitor arm mounts as it would be cheaper and give you more control over monitor locations. with very large monitors or many monitors per mount you get a lever action going on where the weight on the edge will have more effect then it should on paper.
I’m debating between mount and stand. Right now, I have a glass desk so getting a mount is a concern for pressure and breaking issues. It’s a thing piece of glass. I’m thinking about replacing the piece of glass with granite in the future, but for now, this is what I have. So from this, a stand seems more compatible at the cost of desk space. I think I’m okay with this though.
I got this some time ago, it has held up. Currently I have a 27in 4k monitor and two 21in 1080p monitors on it. It took me a minute to figure out the tension system, but once I did getting everything lined up wasn’t difficult.
Probably not the best idea for a glass top desk though.
