Training on 7900 xtx
I’ll try to record my notes here for future people, as I just purchased a 7900 for gaming and ML experiments.
After try the Shakespeare example, I Wanted to train a qLoRA, this is a super efficient 4bit adapter that goes with an existing model.
The process only trains 1/10000 of the model weights so you actually do some training at home… without a computer designed to fight god!
To run the training I had to fix an issue with the bitsandbytes python library, thankfully there was a fork with a solution for Rocm, and with that solved managed to start the train with llama7b, let see how it goes in 8hours!
Paused the training and didn’t restart from the checkpoint so starting over today.
I’ll look into batch size and config, before I try this multi decoder project GitHub - FasterDecoding/Medusa: Medusa: Simple Framework for Accelerating LLM Generation with Multiple Decoding Heads
What is your experience so far?
It’s been solid using the rocm-pytorch container.
And apart from an issue the bitsAndBytes library it’s been going well.
Currently training a model to play Pokemon Red!
I am looking at 7900 xt for nearly the same efforts. Would you say the price is worth it. I’m in Canada and it hard to find a 7900 xt for under $1000.
Amd.ca has the 7900 xt for $1172.
My recommendation would be to buy the card for gaming first and secondly use it for AI.
I didn’t have the option of second hand 3090’s so take that into account before dropping 1k on a card.
Looking at my wandb review and I’ve trained 219 hours now.
Since it’s been hard to find details around 7900 training, I’m sharing the training metric’s below.
I hope its helpful in future!
