Curious to know,
I have a pretty routine problem with Linux and laptops to where the touch-pad will not disable when typing, causing my pointer to fling all over the screen and click on everything. using the Touch-pad G.U.I. that most Linux distros come with does nothing.
so
I use a Syndaemon command (Syndaemon -d something something something) on startup to solve this problem but then my
touch-pad will freeze randomly and, I have to run Synclient TouchpadOFF=O
Is there a solution to this problemo?
For reference I'm using a Lenovo flex 2 (sigh..I bought it for school ok?..it was cheap.) and currently running Linux Mint Rrrrrrrrosa (but i've had this problem using Ubuntu, Lubuntu, Kubuntu, Elementary and even...Opensuse)
