I am settling on: a VA panel, 2560x1440, 144Hz, FreeSync, around $500 Canadian.
Any recommendation on having a curved screen?, at 27" or 32"?
Any thoughts on GSync Compatible options?
Will an RX580 be enough for light gaming, or should I go RTX 2060/GTX1660(Ti?)?
Any insights would be greatly appreciated. I almost went out and grabbed a Samsung 27",1440p, 144Hz, VA panel for $400 CDN tonight (No FreeSync). I am that close to buying.
I wouldn’t bother with a curved 16:9, I have a curved ultrawide and i don’t care either way if it was or was not curved. If curved monitor cost more I wouldn’t even consider it.
As a general consensus from what I’ve heard - it doesn’t really matter once you sit Infront of it.
I will say this - if you look at it from another position or need it for anything else than gaming and basic use - you better get standard monitor. Curved monitor may skew straight lines and curved lines and stuff like that.
580 for light gaming will be just fine. 1440p it may struggle a bit, but in the other hand I was gaming just fine on 270X, so I guess light gaming would be fine…
Depends on the game and the settings. I’m only running 1080p but most games I play on ultra I’m getting between 100-190FPS. Then again I turn off volumetric fog because I hate it and turn off motion blur and dept of field for the same reason.
The only reason I’d even consider a curved monitor is if you get two, for slightly more immersion. This is an opinion, mind you, but I’ve seen dual curved displays and, for me, it looked pretty awesome.
But the viewing angle is crap. You have to be right in the middle of it or it’ll be a nightmare.
I like the curve, it feels like the screen is more ‘in front of me’ at all times. I used to have a 29" 2560x1080 flat and now have a 35" 3440x1440 curved and at that size I think it’s a benefit. The monitor at work is a 38" Dell uw, also curved, and I like it there too even in CAD programs. I would not consider a 29" again, the larger panel is a must have now for me.
For light gaming I think a 580 is the bare minimum, but will definitely depend on the game. A few examples would help too.
I have a curved monitor. To be honest I would only consider curved if your sitting at a desk while using it and your going Ultrawide. I would also like to add, most games don’t scale to ultrawide and you have to go in and manually edit the game settings within the program file.
Save your money and get Freesync, look up compatible to see how people have been getting on with want ever you are looking at as nVidia certainly won’t help you not spend money on them.
